'68 (& '67?) Cutlass/442 4 piston calipers...
Old January 22nd, 2010, 08:39 AM
Indy_68_S's Avatar
I've been studying these as I'd like to convert to front disc on my '68 Cutlass. I know these parts are more $$ , but are still cheaper than Bear/Brembo/Wilwood/SSBC/whatever kit, and want the setup to be as '68 accurate as possible. From what I've learned, the 4 pot actually works rather well, maybe better than the single pot, if setup/maintained properly.
I know that some of the parts are now repro'd...such as the two piece rotor (in both orig 2 piece and compatible 1 piece designs) and I've seen new/rebuilt calipers along with repro backing plates, brackets, lines/hoses, etc..., but most are listed as for Chevelle and some GTOs.
On top of that, some of the 4 pot repros don't look quite right. Example - InlineTube sells this pricey 4 pot conversion, but the calipers look wrong.
Does anyone know the interchange-ability of other '68 A-body parts ? Are the BOP and/or Chevy main components like calipers/brackets the same ? Or are there Olds specific parts ? If so, does anyone have info like caliper casting numbers/etc...for the Olds version ? Pics of an actual factory '68 setup, maybe ?
Thanks...!
Indy_68_S is offline
Old January 22nd, 2010, 09:01 AM
Yes
joe_padavano is offline
Old January 22nd, 2010, 09:16 AM
Indy_68_S's Avatar
Yes
Joe, Thanks!
No I just have to get over the idea of using what may be Chevy parts !
Oh, wait......
R.E.Olds invented the drum brake. Which modern disc brakes evolved from. So....those Chevies are actually using Olds derived parts ! Yeah, that's what I thought!
Old February 11th, 2010, 06:32 PM
rockethound's Avatar
i have a set off a 68 442 spindles out to roters and only one caliper.
rockethound is offline
Old February 11th, 2010, 06:37 PM
Feb11_0006.jpg pictures of right and left disc brake assembly and only one has the caliper the # castings are found on the back of the caliper.
Old February 11th, 2010, 08:36 PM
Indy_68_S's Avatar
PM sent !
Old February 13th, 2010, 10:21 AM
well the set up i had just sold! now i'm going to get all my paint supplies for my car.
Old April 16th, 2010, 01:51 PM
Indy_68_S's Avatar
Alrighty....my disc brake parts collection grows...
Next question, what are the original factory colors for these parts:
Backing plates
Caliper brackets
Hose brackets on spindle
I've seen cars with all different colors.....Example: I've seen the brackets in gray oxide, silver paint, black paint, silver cad, & gold cad (repros are gold).
Anyone have info ? Or pics from a (Lansing) factory car ?
And, wondering...Has anyone compiled a '68 color list for other various components ?
rcktdoc
May 10th, 2014 03:59 PM
blu442
Brakes/Hydraulic Systems
September 16th, 2011 12:32 PM
bobb
February 26th, 2011 07:20 PM
68ragtop
November 24th, 2008 01:57 PM
Quick Reply: '68 (& '67?) Cutlass/442 4 piston calipers...
