Door Glass
Old September 22nd, 2016, 05:49 PM
cus
cus's Avatar
Door Glass
Just about to put the door glass back in my 1973 Delta88 4 door pilarless
sedan. I'm replacing all the seals, is it better to put in without the seals &
then put them in after or visar versa,
regards, cus
cus is offline
Old September 23rd, 2016, 05:50 AM
Put the seals in before installing the glass. The window blocks access to the window sweeps which are between the outer door panel and the window.
Once you install the windows and weather stripping you will need to align the front and back windows to each other and then align them to the car. It's quite difficult. I have a Factory Service Manual describing the procedure, if you plan on doing it yourself make sure you have a FSM. I ended up taking my 71 98 to a glass shop and they did it for a few hundred bucks.
Olds64 is offline
Old September 23rd, 2016, 08:57 AM
m371961's Avatar
Glass adjustment on my 65- 98 was a long slow process and I had the manual. It was slow because I had to stop each time I got frustrated. Heard a rumor,(I think on here.), that the factory allowed the dealer time to finish alignment after the car was delivered. Don't know if it was true but I do not see how Olds got them right on the line.
m371961 is offline
bigdooly
December 17th, 2015 06:03 PM
jeffsims
Body work
June 4th, 2014 05:16 PM
oldsrocket88
March 1st, 2012 04:57 PM
carmax
October 11th, 2011 07:38 PM
Nickthefish
October 16th, 2009 06:15 AM
Quick Reply: Door Glass
