Rear eyebrow rust
If your good with body work or have a friend that is, you can replace just the wheel opening lip. But be sure you get all the rust. You should be able to see part of it from inside the trunk. Then the front part may take a mirror and bright light, going in from the back seat side panel. I've sold a couple wheel well openings to guys with a similar problem. John
And if you find a rust free parts car and cut the fender for a small patch, you should have your head examined!
You are correct. Doing the entire quarter panel is the way to go. Unfortunately I can't afford the extra expense. I don't need a concourse restoration but I don't want to have to redo it in a few years either. I may need to replace the outer wheel housing as well. I don't want to have $20k into a car that is worth $14k. I don't mind being a little bit in the hole but you have to draw the line somewhere. This is not a 442.
The car is from Alabama so the rest of the body is a 8/10. Maybe I will just focus on the mechanical repairs/upgrades and worry about the body and paint last.
im in the same boat except mine isnt half as bad as yours , and mine has rust holes at the bottom behind the wheel..... maybe we can split the cost and buy a rear qtr and cut what you need and ill take what i need ( if i get some money in my hand that I can spend that is )
