OAI hood Airbox or Not
Hello im looking at buying a OAI hood for my 76 442 and was wondering if its worth to spend 150 more dollars on the airbox than not to? i also have no idea what the Airbox would even do? http://www.vfnfiberglass.com/6880cutlass.htm
if i do not have the adapter should i just buy the pin on look a like without the airbox? the airbox hood is bolt on
I would get the one with the airbox because even if you don't have an air cleaner that will work with it right now, it will be something that you can add later on.
where could i pick up lighter springs do you know? what about the hinges. Thanks!
maybe these Brass Springs Or Aluminum Springs they sell might work!? http://www.vfnfiberglass.com/miscparts.htm
Pin on vs. bolt on and hinged is your call. Pin on hoods are slightly lighter, but can flex due to airflow as a result. I had a problem with the leading edge of a pin-on hood fluttering at highway speeds until I added two more pins. Of course, the bigger problem is where do you put the hood when it's off? Lay it on the ground and it gets stepped on. Use a blanket to put it on the roof and you probably need two people to get it off and on. The bolt-on hood eliminates this problem. You can run it without any springs and just use a prop rod also.
oldspackrat
December 4th, 2011 06:26 PM
fast67vellen2o
November 18th, 2011 08:10 PM
