Front/grille 1968 442
When I bolt my new reproduction lighthousings in the correct place,there is not room for the new grille between them.
Wonder If anybody else have experienced this problem.
22 5/8" between the upper side mounts and 19 3/4" between the lower connection points
I've heard the repro 68 headlight buckets take some massaging to fit right. I seem to remember that the studs on the back weren't the correct length too so be careful tightening them down. I think they are slotted already but you may have to slot the holes more in the core support to allow them to sit apart wider.
Do not use this holes without some kind of shim between the housing and the core support,you can break the housing if you thighten all the bolts.
And four of the bolts in the bolt-on set they supply are too short.
75hurstoldsW-30
August 21st, 2014 01:24 PM
halfmoontrail
June 22nd, 2011 11:15 AM
