Front/grille 1968 442
Old August 3rd, 2012, 02:00 PM
jankyrre's Avatar
When I bolt my new reproduction lighthousings in the correct place,there is not room for the new grille between them.
Wonder If anybody else have experienced this problem.
jankyrre is offline
Old August 3rd, 2012, 02:09 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Are the all the through holes through the core support lining up with the head light buckets and the grill? Id suggest loosing everything and fit it up lose then adjust and tighten.
droldsmorland is online now
Old August 3rd, 2012, 02:26 PM
jankyrre's Avatar
The buckets are as far apart as I can get them.
jankyrre is offline
Old August 5th, 2012, 05:34 AM
Humm. Let me take a few measurements when I get home...yes Im at work on Sunday...Double time though!
Old August 5th, 2012, 07:02 AM
allyolds68's Avatar
22 5/8" between the upper side mounts and 19 3/4" between the lower connection points
I've heard the repro 68 headlight buckets take some massaging to fit right. I seem to remember that the studs on the back weren't the correct length too so be careful tightening them down. I think they are slotted already but you may have to slot the holes more in the core support to allow them to sit apart wider.
allyolds68 is offline
Old August 5th, 2012, 12:55 PM
jankyrre's Avatar
This is exactly what I missed the first time.The pair of studs closest to the grill are 15 mm to short.
Do not use this holes without some kind of shim between the housing and the core support,you can break the housing if you thighten all the bolts.
And four of the bolts in the bolt-on set they supply are too short.
jankyrre is offline
75hurstoldsW-30
August 21st, 2014 01:24 PM
jjokrm
April 7th, 2014 04:22 AM
halfmoontrail
June 22nd, 2011 11:15 AM
rallye455
April 14th, 2010 06:24 PM
dkatz
October 22nd, 2007 12:56 PM
Quick Reply: Front/grille 1968 442
