Fender to hood arch
Fender to hood arch
Seems the arch on the fender doesn't match the hood on one side. After going crazy trying to correct I finally noticed the space where the crumples are is wider on the fender with the non matching arch. Looks like it was welded at a different point. I'm installing on my 70 supreme. I bought the donor fender that was off a 442. Is it possible the hoods curve are different. Not sure if this makes any sense but hopefully it does too someone. Thanks for looking.
Large gap under crumples
Smaller gap under crumples are matching curve with hood
Sorry, I made a bit of an assumption there. I’ve never had issues with the arches on factory steel hoods. I would suspect that if there was a misalignment that it would be on the hood side though.
I thought the same thing until I measured the gap below the crumple zone which is greater than the other fender side that matches the hood curve.. Not sure I'm explaining this correctly but there is definitely a different in the 2 fenders
I thought the same thing until I measured the gap below the crumple zone which is greater than the other fender side that matches the hood curve.. Not sure I'm explaining this correctly but there is definitely a difference in the 2 fenders
Sounds like you identified the problem which is half the battle. Could you drill out the spot welds in the area that doesn’t line up and then reweld them after you reshape the fender to match the fender?
Dustin
Dustin
