1970 holiday coupe rear window body panel
Old December 13th, 2016, 08:14 AM
Zr1bandit's Avatar
anybody replace the rear window body panel on a 1970 holiday coupe 442 ?? the panel at the far bottom of the rear window is there a after market piece available for this think its called a tulip panel ?? thanks Greg
Zr1bandit is offline
Old December 13th, 2016, 07:42 PM
marxjunk's Avatar
my whole life, ive always heard it called a tulip panel..when i worked on the line as a bodyman, was called out as a tulip panel on estimates...
marxjunk is offline
Old December 14th, 2016, 04:45 AM
Zr1bandit's Avatar
That's what ive been told also. Is it available aftermarket ???
Old December 14th, 2016, 10:08 AM
delete
droptopron's Avatar
Not sure what you are looking for? is it the inner structure? It doesn't show when the trunk is closed?
File photo for reference
droptopron is offline
Old December 14th, 2016, 10:58 AM
Zr1bandit's Avatar
Yes. Right at the base of the rear window
Old December 14th, 2016, 02:58 PM
71cutlass350's Avatar
The package tray? That would be the flat area behind the rear seats. Not sure if that's what your asking about.
It would be the yellow section.
File Type: jpeg
71cutlass350 is offline
Old December 16th, 2016, 04:12 AM
Zr1bandit's Avatar
This is what i think i need
File Type: png
Old December 17th, 2016, 03:16 PM
I just call that the rear window channel not sure what it's called. It's the same piece as the package tray. I used one out of a donor car and just drilled out all of the spot welds and had it welded in.
Old December 18th, 2016, 07:39 AM
68442's Avatar
No one reproduces that part currently
68442 is offline
Old January 1st, 2017, 06:05 PM
classicmuscle442's Avatar
Need to do rear window channel on mine, is the channel attached to package tray? Or are they one part.
classicmuscle442 is offline
Old January 27th, 2017, 06:46 AM
Picked up a parts car to get the package tray, parts car is very rusty but the tray is perfect, car to be repaired is rust free except for package tray.
nolabigdawg
October 13th, 2014 07:05 AM
Oldssupreme
December 6th, 2012 06:08 AM
62radarlove
March 9th, 2012 09:02 PM
1970w30
May 24th, 2011 07:31 PM
oils66
November 25th, 2009 08:25 AM
Quick Reply: 1970 holiday coupe rear window body panel
