holiday coupe vs sports coupe
Old November 21st, 2009, 12:13 PM
oils66's Avatar
on a 69 cutlass does the holiday coupe have the vent windows on the doors and sports coupe has not. mine is a 69 ''s'' with cowl tag #33687 and i have the vent windows.can this be converted to a non vent style.
oils66 is offline
Old November 21st, 2009, 01:41 PM
Diego's Avatar
"Holiday" is Oldsmobile's term (dating back to 1949) for hardtop, just like Buick hardtops used to be called "Riviera." Not being a '69 expert, I believe only the post coupes and sedans had the vent windows but your VIN suggests a Holiday.
Diego is offline
Old November 21st, 2009, 03:30 PM
Trying to remember member
wmachine's Avatar
Correct, the post coupes and sedans have the vent windows. But they have full window frames too. If you have vent windows and no window frames, it sounds like you have '68 hardtop doors on your '69.
wmachine is offline
Old November 21st, 2009, 03:44 PM
Conversion?
Good 2nd question. I'm not a bodyman but I'll go with the following reasoning. I think it's not an easy change to make. Why?
The post coupes will have an inset on the roof line to accomodate the post frames and the weather stripping. All the GM lines with framed door glass I've seen (60's - 80's) have the weather seal attached to the door. The coupes without framed glass have the weather stripping set into a molding that is fastened to the roofline molding. The rest of the weather seal runs along the inside of the door. I don't know whether the roofline is generic or not. Someone with expert knowledge, please step up to the plate??
Allan R is offline
Old November 21st, 2009, 10:33 PM
svnt442's Avatar
The roof is the same, they just add the pillar to close off the rear window.
You can't just remove the frame from the door as there would be no way to seal the glass. On top of that it wouldn't go up far enough to get anywhere near the roof.
svnt442 is offline
Old November 22nd, 2009, 06:57 AM
Sorry, but there is MUCH more to it than that. The roof is about the ONLY piece that's common. The glass is all different, the window tracks and mechanisms are all different, the roof rail supports and weatherstrips are all different... you get the idea.
As for the OP's 1969, the VIN shows it to be a Holiday Coupe, which should NOT have vent windows. Either you have 1968 doors (not a trivial swap) or the VIN has been changed.
joe_padavano is offline
Old November 22nd, 2009, 09:08 AM
oils66's Avatar
my vin matches the protect-o-plate, but sequence # on those do not match cowl tag sequence. vin= 224062 and cowl= 223714. why would someone change a cowl tag? also, i do not have the post between front seat glass and rear seat glass.so, if i have 68 doors, i should be able to change back if i can find doors with glass,right? anyone have any thoughts or ideas. thanks.
oils66 is offline
Old November 22nd, 2009, 10:38 AM
wmachine's Avatar
Yes, it does sound like you have '68 doors. Cowl tag and VIN *won't* match, as the they are not the same number origin. The cowl tag number is the Fisher Body sequence number and not related to the VIN.
Yes, you should be able to use '69 doors, but I image the mating seals/channels on the body were changed to '68 pieces to make the door fit, so you may need those too.
What is the build date of your car? Code is on the body tag, like 10B.
wmachine is offline
Old November 23rd, 2009, 07:24 AM
oils66's Avatar
wmachine, i have a 12b on body tag. i thought that was a trim # and seat type. there is a 940 just above the 12b.
oils66 is offline
Old November 23rd, 2009, 07:59 AM
wmachine's Avatar
12B is 2nd week of December, so it precludes any possibility of a production freak by being one of the first '69s possibly having '68 parts.
What is the full model number on the data plate?
wmachine is offline
Old November 24th, 2009, 03:38 AM
oils66's Avatar
st 69 33687lan223714 bdy
tr 940 40 40 pnt
12b
oils66 is offline
Old November 24th, 2009, 07:22 AM
tr 940 40 40 pnt
12b
Well, definitely a 1969 Holiday Coupe. Doors (and roof rail weatherstrips) have been changed.
Old November 24th, 2009, 08:35 AM
wmachine's Avatar
X2. Can't imagine any other possibility.
wmachine is offline
Old November 24th, 2009, 03:13 PM
oils66's Avatar
thanks for the help guys. i did some snooping in the parts book tonight to see if i can keep my doors and change glass to stock (no vent window). weather strip & regulator #s are different and of course the glass itself. i will start searching for regulators and glass tonight. if anyone knows that this swap won't work, please chime in.
oils66 is offline
Old November 25th, 2009, 08:25 AM
It's probably easier and cheaper to just get 1969 doors.
coldfire
August 13th, 2019 08:08 PM
Caruso
July 20th, 2015 05:43 AM
sosfrog
Cars Wanted
May 4th, 2014 05:57 AM
1970w30
May 24th, 2011 07:31 PM
mvonhobe
July 28th, 2007 04:32 PM
Quick Reply: holiday coupe vs sports coupe
