BOLTING DUAL GATE TO TRANS TUNNEL
Old November 3rd, 2009, 03:48 PM
'71 Convertible
LIMEGREEN71's Avatar
I'm converting a factory column shift car to a Dual Gate with a console. Did the factory floor shifter, either Dual Gate or regular, bolt to the floor with a large sheet metal fastener, or was it a bolt with a nut welded in the underside of the transmission tunnel. Thank you so much for any experience with this!
LIMEGREEN71 is offline
Old November 3rd, 2009, 04:00 PM
70 cutlass s's Avatar
They use a mounting bracket you can order a replacement. At Year One their about 105 bucks. You might also try the Parts Place.
70 cutlass s is offline
Old November 3rd, 2009, 09:28 PM
2blu442's Avatar
Dual Gate Hold down fasteners
It's been a few years since I pulled one from the floorboard, but I'm 99% sure it was sheetmetal type screws. Very similar to the ones that hold the bolt on center caps on SSII wheels. John
2blu442 is offline
Old November 3rd, 2009, 10:28 PM
svnt442's Avatar
^^^^^^^What he said. They just bolt to the floor.
svnt442 is offline
Old November 4th, 2009, 04:11 AM
Ok yes if it already has the bracket on it and than use sheet metal screws. If got the complete shifter than it does.
kitfoxdave
June 6th, 2011 07:02 AM
Olds92
October 25th, 2010 09:05 AM
olds455
June 5th, 2010 07:15 AM
BerBer5985
January 14th, 2010 08:53 PM
Quick Reply: BOLTING DUAL GATE TO TRANS TUNNEL
