ajusting hood
ajusting hood
Hey heres one I think we all have delt with my hood wont go all the way down in the rear when its closed unless I push it down with my hand I have tryed ajusting it, all the gaps are even all the way around What gives? is it the hinge? it apears to be good. any ideas?
If I remember correctly, it's the opposite of what you'd think. To make the rear end of the hood close further, you lower the front end of the hinge.
It may also help to clean and lube your hinges so they move freely. They may simply be binding from grit or lack of lubrication.
I know this may sound weird but, if the hood SPRINGS are worn you will encounter this problem. Of course proper alignment is necessary. If the hood is aligned and affter closing the rear is raised and will lower after pushing it down, it is usually the springs. Lowering the rear of the hinge will not only mis-align the hood, it will change the the tension on the front catch (latch).
Sometimes the opposite side is pulling down and therefore raising the other. You might try shiming the other hing between it and the hood. This possibly will lower the side you have to push down. Its all trial and error.
Also look on the hinges for worn rivets and or a slot forming around them.
Sure did and it is the hard rubber one Ill try the shim first if that dont work I will try taking the seal out and see what it does
Trimmed the end of the seal it was a little long one that end and it helped a bunch but it still needs to be pushed down a little I dont remember were I bought it from eather yearone or opg im going to see if I can find it.
X2, this is how I got my hood to fit flush at the back, also, the rivets do wear out in the hinges, if the joint is loose a BFH and a dull chisel can be used to tighten loose hood hinge rivets.
Thanks Tony
guy.graziano
December 5th, 2010 12:10 PM
georgiaboy697
July 2nd, 2010 09:23 PM
