1969 cutalss front bumper brackets diagram
Old February 2nd, 2017, 09:21 AM
hotwheels69's Avatar
I need to install the front bumper and bumper brackets for the 69 cutlass. i don't have an assembly manual. I am looking for a pic of how the brackets install onto the frame. I have those studs with the built in spacers and ridged washers but don't remember how they go. Any help is appreciated
hotwheels69 is offline
Old February 2nd, 2017, 10:17 AM
Randy C.
rcorrigan5's Avatar
The attached page should do the trick for you.
Randy C.
rcorrigan5 is online now
Old February 2nd, 2017, 04:08 PM
Yellowstatue's Avatar
The attached page does not show the stud with the built in spacer, it shows simply a bolt. On a '68 the stud with the incorporated washer goes into the frame (to the outboard) with the long portion and bumper bracket, and the short end goes through the brace with a washer and nut on each end of the stud.
Yellowstatue is offline
Old February 2nd, 2017, 04:49 PM
Randy C.
rcorrigan5's Avatar
Ah, yes, I see what you mean. I scanned the same page from the '68 assembly manual (attached) and it shows where the stud goes and how it is attached.
I have both a '68 and a '69 and both are assembled per their respective assembly manuals. It makes me wonder if early production '69s were assembled with the stud to exhaust old supply before digging into the new supply. It wouldn't make any difference in strength/support and no one would know or see it anyway unless people got into them like we do!
Randy C.
Old February 2nd, 2017, 04:52 PM
Randy C.
rcorrigan5's Avatar
I rotated the pic so it would be easier to see.
Randy C.
Old February 2nd, 2017, 04:57 PM
Can't you rotate the picture with the edit function?
Old February 2nd, 2017, 07:05 PM
Randy C.
rcorrigan5's Avatar
I know some people have done it. I've tried it but, no matter what I do, it doesn't work. So I just post again!
Randy C.
jimlinnell
December 17th, 2023 06:02 AM
yankees
Drivetrain/Differentials
June 11th, 2013 06:24 AM
67BB
Suspension & Handling
March 1st, 2013 06:49 AM
delta254
December 3rd, 2012 06:24 PM
etohboy
January 27th, 2010 08:27 PM
Quick Reply: 1969 cutalss front bumper brackets diagram
