Safest way to clean up cylinders and mains-Inspection
Old April 8th, 2012, 11:05 PM
XCELERATIONRULES!
Nasty455's Avatar
I finally cleared some engine stands in my garage.
I have a couple engine blocks that need inspection and bore measurements.
They have both been sitting in a garage for years and have some rust in the cylinder bores...they are just blocks with cam bearings installed.
I want to clean up the cylinder walls and main caps and get some measurements.
Fine emery cloth?
Thanks guys.
Nasty455 is offline
Old April 9th, 2012, 11:06 AM
m371961's Avatar
I think I would use a lot of WD-40 and a ball type hone. (dingleberry)
m371961 is offline
Hawghead
August 19th, 2014 06:10 PM
hotrodpc
August 31st, 2011 01:12 PM
Dant
August 10th, 2011 04:09 AM
geckonz08
January 28th, 2011 08:55 PM
Quick Reply: Safest way to clean up cylinders and mains-Inspection
