Edelbrock Torker, your thoughts?
Old April 13th, 2010, 12:10 AM
Prsabordo's Avatar
Found a torker for cheap for a stock 455, will this be a good setup for the olds along with a quadrajet? Also what quadrajet should go with the Torker?
Prsabordo is offline
Old April 13th, 2010, 06:36 AM
70 cutlass s's Avatar
I wouldn't recommend using a torker on a stock 455. Performer would be a better choice. Your stock carb would be fine.
70 cutlass s is offline
Old April 13th, 2010, 08:57 AM
71cutlass455's Avatar
My 455 came with the Torker, and edelbrock carb. What do I need to do to get performance out of it since it doesnt work with a stock engine setup? Would a cam be enough? or do I need to dig into the valvetrain?
71cutlass455 is offline
Old April 13th, 2010, 09:48 AM
Prsabordo's Avatar
the stock carb we have now is a 2 brrl, u still recommend we use it with the performer?
Old April 13th, 2010, 08:59 PM
A four barrel Q-jet would work great with it, or a aftermarket carb. 750cfm with vacuum secondaries.
Old April 13th, 2010, 09:02 PM
To get the most out of it. You would need cam, stall converter, and gears. To make it work the best. The Torker is made to work with a power band starting at 2,500 rpm.
Old April 13th, 2010, 09:08 PM
So as of right now, I am losing power, or it just isnt being used properly? Dang... Just when I thought Ive poured enough of my hard earned money into it :*(
Old April 14th, 2010, 04:57 AM
cutlassefi's Avatar
Performer.
cutlassefi is offline
69CutlassAlex
July 30th, 2013 08:18 AM
455cutlass1969
April 9th, 2012 11:13 AM
Prsabordo
April 13th, 2010 05:02 AM
Topless72
November 20th, 2008 08:13 PM
Quick Reply: Edelbrock Torker, your thoughts?
