Mystery 455
#81
Check this thread:
Painting Aluminum Intake
Really? I'll give it a try tomorrow. And we're talking off-the-shelf brake cleaner, right? The castrated weak stuff? Or do you "know people"? Lol.
#83
I've only used the red cans, never seen green but I'll look. My first choice would be to leave it unpainted. I wish I knew what kind of paint it was. That blue metallic stuff.
#84
Brake cleaner indeed took more paint off. I soaked the areas for a bit then used a stiff bristle artist brush on them until the bristles were gone.
I realize I probably won't have the hood clearance for the spacer (although I did on my small block) but I wanted to see how it looked
#86
#89
Bored, line honed, decked, and look at those lovely ARP studs
Check out these little gems.....
Last edited by Macadoo; August 12th, 2017 at 03:48 PM. Reason: vocabulary correction
#90
That is looking sweet. Be sure to measure the center of the crankshaft to the center of the camshaft, just to make sure that you can still use a stock length timing set, or you may need an undersized timing set (measure before you buy).
#91
I wouldn't have thought about that. Thanks Joe. The motor came with a new double roller timing set. I can at at least use it to verify fit. I'm not sure if I would trust it for final assembly. There's no brand name on the gears that I can see.
#92
Come to think of it; am I going to have clearance issues with the ARP main bolts and the oil pan? Since the block is still in Streator and the pan is with me at home, I can't check.
#94
Carb cleaner removes paint much better than brake cleaner. The VHT aluminum works very well, get the flat aluminum in the extra high temp. Doesn't matter what brand the timing set is as long as you degree it. My Cloyes Street Roller was spot on, Cloyes Billet Roller is nicer and my custom cam from Cutlassefi was also very close on all it's specs. Degree your cam! This was the first cam I degreed, very glad I did it.
#95
#96
I pieced one together.
11" degree wheel (Moroso maybe, larger diameter is easier. You can even find web sites with a printable wheel)
Amazon has some for under $15
Dial indicator and magnetic base from Enko Tools (now MSC Direct). Cost under $30 back then
https://www.mscdirect.com/browse/tn/...7&sortby=price
I measured off the edge of a lifter and used a piece of wire clothes hanger for a timing pointer.
#97
https://www.amazon.com/s/ref=nb_sb_n...3Adegree+wheel
#98
#102
#104
Mac, this is good info Copper is giving. I would still check it to make sure your crank shaft is on target, and most of all the its installed correctly. That degree wheel is easy to read. You can measure the intake opening event, and that should be sufficient.
#106
I forgot to add that to the list I posted. I made one by breaking the ceramic out of an old spark plug, threading the inside of the hex portion, and inserting a long bolt into the new threads.
Voila, adjustable piston stop.
edit: Here's a web pic that is very similar to the one I made:
#108
Mac i still have the cam card and yes degree it in . My degreeing set up is what most would call ghetto but it worked enough for me to know everything was happening when it should. In the next few weeks i will yank that stuff from the engine on the. stand
#111
I'll probably use plastigauge AND my bore gauge but I don't trust my bore gauge skills, lol. Measure the OD of the crank journals and set the bore gauge to that diameter then measure the ID of the mains, yes?
#113
With the piston stop, you only really need a degree wheel and the checker lifter. I used a piece of solder for the pointer.
#114
