Intake Question
Old December 1st, 2016, 06:12 AM
67Rocket's Avatar
Intake Question
On a basically stock 455 other than weight, do you guys see any improvement in using an Edlebrock Performer over a factory
4 bbl intake? Thanks
67Rocket is offline
Old December 1st, 2016, 06:14 AM
You get a cool sticker with the intake. Buy one, buy one now!
Really though, I've heard that the Edelbrock Performer is a clone of the stock intake, the only difference being it's aluminum and not iron. If you're looking for fast HP I suggest a cam and dual exhaust before buying an intake.
Olds64 is offline
Old December 1st, 2016, 06:58 AM
You have heard incorrectly. The factory W-30 intake is a clone of the stock iron intake. The Performer has different runner geometry. It's not a massive difference, but it is different. Biggest difference is the "T" intersections in the runners, as is obvious in these photos. Not the best for flow.
W-30 (stock iron is the same shape):
Performer 455:
joe_padavano is online now
Old December 1st, 2016, 08:12 AM
I still suggest a cam and dual exhaust over an intake. You need a highly calibrated butt dyno to notice the difference an aftermarket intake manifold will make on an otherwise stock motor. Then again there's always the sticker...
Olds64 is offline
Old December 1st, 2016, 08:21 AM
Increasing HP requires increasing airflow through the motor. That means that EVERYTHING needs to be matched - intake, exhaust, cam, carb, etc. Any one change may make a small improvement, but these changes leverage each other. Evaluate the most restrictive part of the airflow and fix that first. Then move on to the next, etc...
Old December 1st, 2016, 04:59 PM
wr1970's Avatar
100% on the spot. Getting the performer intake is a good place to start.
wr1970 is offline
Old December 3rd, 2016, 06:09 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
The BBO Performer is noticeably taller than the factory intake. The SBO Performer intake is much closer to stock. Longer runners and better plenum area mean more power. When Edelbrock added the non EGR SBO Performer intake, they should have copied the BBO version for carb height.
olds 307 and 403 is online now
TIM FISKUS
May 12th, 2013 05:17 AM
Wildcard
December 26th, 2012 07:48 AM
Nickyloves442s
October 24th, 2012 04:55 PM
svnt442
July 17th, 2011 04:43 PM
71cuttyS
October 31st, 2007 04:58 PM
Quick Reply: Intake Question
