How to get specs for installed camshaft (NO I DONT HAVE THE CAM CARD)
Old May 14th, 2012, 11:53 AM
jpaulwhite's Avatar
I got my dial indicator hooked up like this:
All I gotta do now is turn over the engine and read it correct? I just need to measure the maximum lift right?
Paul
jpaulwhite is offline
Old May 14th, 2012, 01:48 PM
same but different
don71's Avatar
You take that reading and then times that by 1.6. Which is the rocker arm ratio.
I suggest you take the reading in couple of different places. At least two intakes and at least two exhaust valves,then average them independantly. That way you can see if you have a dual or single pattern cam.
xyz X 1.6 = lift
don71 is offline
Old May 14th, 2012, 01:57 PM
jpaulwhite's Avatar
xyz X 1.6 = lift
My plans exactly. And thanks,
Paul
Old May 14th, 2012, 04:25 PM
cutlassefi's Avatar
xyz X 1.6 = lift
Uhh dude, he's taking it at the valve, technically he'll have to divide it by 1.6 to get lobe lift, you have it backwards.
Also that won't be accurate anyway. By the time the lifter bleeds down etc it'll change the lift figure a bunch.
Remove the rocker and measure it on the lifter side, then times it by 1.6. Doing it on the lifter side will be way more accurate. Good luck.
cutlassefi is offline
Old May 14th, 2012, 04:46 PM
jpaulwhite's Avatar
Thanks!
Ill post the results, not doing it tonight as its raining.
bwichman
June 17th, 2020 10:51 AM
kelly bakies
June 12th, 2014 08:34 PM
CyberCholo
April 13th, 2014 07:01 PM
w-30dreamin
March 19th, 2010 04:22 AM
johnfharding
February 8th, 2009 07:52 PM
Quick Reply: How to get specs for installed camshaft (NO I DONT HAVE THE CAM CARD)
