Help..help....hei
Old June 8th, 2013, 08:40 AM
scooter123's Avatar
Help..help....hei
Sorry for starting a new post guys but I have to get this fix asap...going to a show today...I hope!!
So I got the car to start this morning but the new hei is making a clicking sound....and I got one hell of a shock
so the coil instructions said to ground using the coil screw..as you will see in my first pic
The plug from my new distributor has three wires that is 1 yellow....1 red....1 black that hooks to nothing.....is there suppose to be a ground wire of some sort going to that black wire on the distributor plug???
scooter123 is offline
Old June 8th, 2013, 08:56 AM
Oldsmobile enthusiast
s i 442's Avatar
That plug will plug in only one way most likely the red wire towards the firewall.
If there is no ground wire don't worry about it.
s i 442 is offline
Old June 8th, 2013, 09:00 AM
scooter123's Avatar
As I said...im getting a major spark leak...and clicking noise.....all videos Ive watched online shows a ground strap under the coil.....and the spade connects to the black on the distributor plug
Old June 8th, 2013, 09:02 AM
Octania's Avatar
the coil has to ground somewhere
It's been a while but I think you are missing a "wire" that is a formed pc of conductor from the center terminal to where the coil's black wire is secured at a mtg screw.
Octania is offline
Old June 8th, 2013, 09:33 AM
scooter123's Avatar
Just went back to napa and got the right ground strap
Old June 8th, 2013, 10:59 AM
scooter123's Avatar
All is good with the new distributor/hei...thanks for the help guys!!!1
Old June 8th, 2013, 02:04 PM
Well how does it run? What did you set your timing to?
oldcutlass is online now
joepenoso
June 4th, 2014 01:56 PM
Mark71
November 13th, 2011 11:00 AM
oldscruiser
February 15th, 2011 12:44 AM
chopper charlie
Tech Editor's Desk
August 3rd, 2010 06:04 PM
dallasite21
January 30th, 2010 04:57 PM
Quick Reply: Help..help....hei
