Engine Removal 61 Olds 394 Eng
Is it easier to pull just the engine versus pulling both the engine & trans together. Would like to get some advice on this as I pulled the trans last yr & replaced the seals so I really don't need to pull it out again but can't find any info on just pulling the engine so if anyone out there can tell me which is easier I would appreciate it & if you have any tips/short cuts I would be up to that info also. Thanks.
This thread is about a 64 but the information is the same as they are very similar.
https://classicoldsmobile.com/forums...e-removal.html
wr1970
March 29th, 2015 05:36 AM
ohiocutlassparts
January 12th, 2014 04:12 PM
