Do I need to add leaded additive to my fuel
Old July 20th, 2013, 10:59 AM
stirlingguy's Avatar
Hi everyone ; I`ve not posted much but really enjoy the great collection of experience and priceless knowledge in the collective group . I was wondering if not using leaded fuel could cause some long term damage ? I usually put 91-94 octane in my car and it really seems to run great . The previous owner had it tuned by someone that really knew what they were doing ,it will start first spin . Thanks J.R.
stirlingguy is offline
Old July 20th, 2013, 11:05 AM
The general consensus is that unless you do sustained high-speed / high-load operation (such as towing), you shouldn't need it.
The question for anyone who says you have to use it, is have they ever actually seen an Olds head, that experienced normal use, with exhaust valve recession.
MDchanic is offline
Old July 20th, 2013, 11:14 AM
Junkman's Avatar
I have not used a lead additive in any of my collector cars, and I have not had one problem as a result of the missing lead component of the current gasoline. I have had detonation issues as a result of the low octane content of the gasoline, and I hate the use of ethanol in the fuel, since it deteriorates the rubber components in the carburetor.
I can remember when my brother purchased his new 1958 Chevy Impala with the fuel injection engine. He started using Amoco "white" gasoline, which had no lead additive in it. It ran perfectly well, and there was never any engine issues. Back then, there was a belief that the lead was bad for the fuel injection units. I also ran the white gas in my 1959 Impala 348 with a standard Rochester 4 barrel carb, and never had a problem. I think that the myth has grown out of proportion to fact in the years since lead was removed from gasoline. The lead (tetra ethyl) was added as a octane booster, and had nothing to do with valve issues. It did form a coating on the exhaust valves, and left the tail pipe with a nice white coating if your engine was running correctly.
Junkman is offline
Old July 20th, 2013, 11:24 AM
brddg's Avatar
X2. When having my heads done last year the machinist called them "virgins" yet I was still nervous and did much trolling on blogs. The comment that made the most sense was the hardening from the factory doesn't make it through the 2nd valve job and you don't hear of hardened seats being re-installed.
brddg is offline
Old July 20th, 2013, 11:29 AM
X3 on not having to run it.
oldcutlass is online now
Old July 20th, 2013, 11:43 AM
Tedd Thompson's Avatar
X4 and have run regular gas in my 327 powered Land Cruiser for over 10 years with no problems.
I did have my 55 Olds heads reworked (three angle valve job) when it was time to rebuild them just to be on the safe side...Tedd
Tedd Thompson is offline
Old July 20th, 2013, 03:26 PM
Thumbs up
Thanks all for your input and I think at this point in time that if it isn`t broke don`t fix it .J.R.
Old September 2nd, 2013, 03:31 AM
AlanT's Avatar
When I lived in PA in the early 80s I could take my 73 "COOP DEEVILLE" to a place in Pottstown that sold LEADED fuel! I bet its no longer there
AlanT is offline
67Rocket
June 29th, 2015 04:31 PM
navvet
August 26th, 2013 07:06 PM
MudEye
June 6th, 2013 07:18 PM
dkatz
November 8th, 2007 08:46 AM
72RocketPower
February 25th, 2005 12:41 PM
Quick Reply: Do I need to add leaded additive to my fuel
