deep springs pocket?
Old May 14th, 2017, 11:50 AM
Tiha's Avatar
- G heads...are these deep springs pockets?
Tiha is offline
Old May 14th, 2017, 01:51 PM
edzolz's Avatar
I can't tell, but all deep springs used the rotator keepers and these are not rotators.
edzolz is online now
Old May 14th, 2017, 11:16 PM
Tiha's Avatar
Where all valve train parts are include (keepers-springs-locks-rotators), must I pay any attention to any details if rotators or not rotators…any extra machining requiring ?
Tiha is offline
Old May 15th, 2017, 06:52 AM
G heads should have rotators - and thus deep spring pockets - on the exhaust valves only. If you decide to delete the rotators to reduce mass and improve peak RPM, then you MUST shim the deep spring pockets to achieve the correct spring installed height. This is basic head assembly 101.
joe_padavano is offline
Old May 16th, 2017, 08:50 AM
80 Rocket's Avatar
Not necessarily true. Using different locks and retainers can get you around .100" +/-. Plus, being an exhaust valve, it doesn't need as much spring as the intake valve so the installed height can be slightly more than the intake.
On the same note, you can add installed height to the intake with locks retainers......while taking some away from the exhaust.
Or, you could just machine the shallow spring pockets to the depth of the deep pockets. Although, I get a little leery of that.
I really don't like using shims, especially if you have to use a lot of them. If I am going to stack a bunch, I get a valve spring locator and stack a few shims underneath so the valve spring has better control.
80 Rocket is offline
Old May 20th, 2017, 01:02 AM
Tiha's Avatar
]Not necessarily true. Using different locks and retainers can get you around .100" +/-. Plus, being an exhaust valve, it doesn't need as much spring as the intake valve so the installed height can be slightly more than the intake.
I really don't like using shims, especially if you have to use a lot of them. If I am going to stack a bunch, I get a valve spring locator and stack a few shims underneath so the valve spring has better control.[/QUOTE ]
can i use a complete kit like this http://www.compperformancegroupstore...Code=K42-228-4
with all types of heads (rotators or not rotators) without machining ?????
Tiha is offline
455man
May 4th, 2013 11:58 AM
jahlyfe'scutty
January 16th, 2013 01:45 PM
yeahbuddy
December 18th, 2012 06:16 AM
zodiacblueS
Paint
July 22nd, 2012 12:08 PM
442_Mustang
September 25th, 2011 05:49 AM
Quick Reply: deep springs pocket?
