Moisture between head and exhaust manifold
Old May 19th, 2017, 03:15 PM
71cutlass350's Avatar
I recently replaced the head gaskets, timing chain, intake gasket, etc... , and also had the heads rebuilt on a 71 455 and I'm still trying to work the bugs out. I noticed between the head and the exhaust manifold there always seems to be moisture between the too and when it warms up it smokes. This is only on the drivers side right above the dipstick. I'm assuming its oil but I have no idea where it comes from or what causes it. Hopefully nothing serious but this has been a learning curve for me so a mistake on my part is possible.
71cutlass350 is offline
Old May 19th, 2017, 03:19 PM
You need to determine if it's oil or coolant. Most likely it's your valve cover.
oldcutlass is offline
Old May 19th, 2017, 03:42 PM
Should have added that in, I originally thought it was oil from the valve cover because it was leaking slightly right above the moisture areas so I went ahead and put a new one on and made sure it sealed up good with no leaks now, however the smoking and wetness is still there. Ill see if I can figure out if its oil or coolant.
Old May 19th, 2017, 03:57 PM
Use some simple green or ivory dish soap and wash the area and see if it comes back.
Old May 19th, 2017, 05:03 PM
Sprayed simple green and scrubbed it good, Ill let it dry and start it up tomorrow and see if I can spot where and what is seeping out. Thanks
Old May 19th, 2017, 05:05 PM
Olds Scott's Avatar
Did you seal the threads on the manifold bolts for installing
Olds Scott is offline
Old May 19th, 2017, 08:05 PM
same but different
don71's Avatar
The five exhaust bolts on an Olds should not reach water, unless there is crack or some other condition present. I might suggest the addition of a dye and uv light to narrow it down after you've done what is already suggested.
don71 is offline
Old May 20th, 2017, 06:10 AM
ROCKETMAN269V's Avatar
Do you happen to recall what head gaskets you used, brand and part #?
ROCKETMAN269V is offline
Old May 20th, 2017, 06:50 AM
I used FEL-PRO 8171PT1 and didnt put any sealent on the threads of the bolts.
Old May 20th, 2017, 06:52 AM
boese1978's Avatar
I have seen this a little bit on mine, I chalked it up to the diff in material between the aluminum head and the different metal of the manifold, they cool and heat at different rates. Obviously if you have stock iron this would not apply. Mine is plain old condensation- I used toilet paper to see the color of the "water".
boese1978 is offline
June 3rd, 2019 11:53 AM
olds 307 and 403
February 25th, 2017 03:15 PM
biggus
May 22nd, 2015 05:31 AM
68 Cutlass S
July 26th, 2009 12:11 PM
The Stickman
February 19th, 2009 06:44 AM
Quick Reply: Moisture between head and exhaust manifold
