Bad viscous clutch?
Old April 22nd, 2017, 05:23 PM
bw1339's Avatar
Bad viscous clutch?
Hello,
The mechanical fan in my '66 Toronado is blowing quite a bit of air while the engine is cold. I've had viscous clutches die and they would not engage - Does the opposite happen (as in they remain engaged)?
I waited until the engine got to temperature and did not see a difference in airflow from the fan.
Thanks.
bw1339 is offline
Old April 22nd, 2017, 09:27 PM
That can be normal. The fluid in the clutch has to warm up a bit before it functions normally.
It's usually not that pronounced, and only for a few seconds before it calms down, but I don't think there's a hard and fast rule about it.
One possibility is that a PO changed to a heavier duty clutch - when I had a 2797 on mine, it'd blow like crazy for the first ten minutes or so of driving, before settling in.
MDchanic is offline
Old April 23rd, 2017, 03:49 AM
bw1339's Avatar
Thank you.
I figured it couldn't freewheel completely, as the A/C wouldn't work until the engine got warm.
bw1339 is offline
Old April 23rd, 2017, 08:33 AM
My 2001 Dodge Ram diesel sounded like a garbage truck for the first few minutes of driving after startup. Its normal.
oldcutlass is online now
RandyS
July 6th, 2021 07:45 PM
odddoylerules
April 21st, 2014 07:54 AM
47 Convertible
April 3rd, 2014 07:56 AM
RandyS
March 8th, 2014 05:07 AM
airmale
November 13th, 2013 11:15 AM
Quick Reply: Bad viscous clutch?
