425 toro pulley setup
Old February 4th, 2014, 05:12 PM
Mostly Gristle
bluecab's Avatar
Looking for some help with the pulley setup on my '66 425 Toro motor.
The 2 pulleys that are on at the moment are crank and water pump, as it sits at the engine shop.
Problem is, they don't line up with each other.
As my motor came disassembled I don't know if the pulleys are wrong, backwards or ?
I don't have photos to post, but hope some of you with 425 motors might post up a pic or two.
TIA,
David
bluecab is offline
Old February 4th, 2014, 05:18 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
This is usually due to an incorrect water pump installation. With the water pulley removed.... Measure from the pulley flange to the timing cover face with a straight edge and a tape measure. Should be 5.1"
If it measures 5.6" or 6.1" ....you have the wrong water pump.
5.6" is 68-70 and 6.1" is 71-90 with a/c
J-(Chicago) is offline
Old February 4th, 2014, 06:32 PM
Mostly Gristle
bluecab's Avatar
Thanks, J
I thought all the junk that came with the car was original, but who knows?
I'll measure it up as soon as I can.
Thanks!
bluecab is offline
heavydan
August 18th, 2014 05:07 PM
vistacruiser1971
December 27th, 2012 07:35 AM
84 Calais
July 16th, 2011 02:33 PM
longboardguy
June 25th, 2009 04:48 PM
longboardguy
June 15th, 2008 12:30 AM
Quick Reply: 425 toro pulley setup
