394 highway speed lifter noise
I have a 61 Dynamic 88 with the 394 2bbl. Just recently it started making a fairly loud lifter/valve noise but only at highway speed around 70mph. Sometimes all I have to is get off the highway and cruise around 50mph and it goes away, other times I might have to let it sit for 10 minutes and then it's fine. If I cruise the back roads around 50-55 mph It will go all day without any noise at all I'm not a mechanic but I'm not mechanically challenged either so I was thinking possibly a gummed up screen on the oil pump or something like that perhaps? Any thoughts on this would be greatly appreciated thanks, Jeff.
My old 63 394 would go 3000 miles between oil changes without a noise any miles after that and a lifter would stick. Try a oil change and a pint of your favorite upper valve train lubricant and see what happens. Sticky lifters are common on all first generation Old's V8's.... Tedd
If it is lifter noise and not rockets then you should use E.O.S. engine oil supplement which was designed for the 394 lifter noise. I add it when I do an oil change and it works, the product is available here at any GM dealer and any AC Delco dealer/jobber parts supplier.
Steve
Steve
