Engine RPM at Highway speed??
Old September 12th, 2011, 07:01 PM
Land Yacht Captain
66ninetyeightls's Avatar
Can anyone with a 66 Ninety Eight or similar full size tell me what engine RPM I should expect to see at 60MPH(100KPH)??
I just got a new tach and its reading close to 5000RPM at that speed. I know that is WAY off and the tach is bad. I just want to know what I should be looking for when I install the replacemnt tach.
66ninetyeightls is offline
Old September 12th, 2011, 07:13 PM
I don't have the specs at my fingertips, but I believe that a stock '66 should have anywhere from a 2:56 to maybe a 3:31 gear, so 5,000 RPM @60mph is out of the question.
Does the tach have a selector for number of cylinders?
Is it connected to the negative coil terminal (the one that goes to the points)?
MDchanic is offline
Old September 12th, 2011, 07:16 PM
Land Yacht Captain
Yeah its set to 8 cylinder and is connected to the coil negative. I'm pretty sure its just a bad tach as it was pretty cheap 2" unit.
Old September 12th, 2011, 07:27 PM
72 cutlass455's Avatar
Think it would be 2250 to 2600 could be as high as 3000 but would think it would be some where in that range.
72 cutlass455 is offline
Old September 12th, 2011, 08:23 PM
1974 DELTA 88
AZ455's Avatar
Not sure if this will help, but my Eighty-Eight turns around 2500 rpm @ 65-70mph.
AZ455 is offline
Old September 12th, 2011, 10:02 PM
Jaybird's Avatar
Craig: My '67 Delta 88 has a 3.08 rear end. I had my tach recalibrated last year. It reads between 2500 and 2600 rpm at 60 mph. I run the correct diameter tires, 235/70/15 (28").
Jaybird
Jaybird is online now
Old September 13th, 2011, 12:00 PM
Land Yacht Captain
Great thanks. I will check it out once I have a decent tach installed.
Old September 13th, 2011, 12:10 PM
VikingBlue's Avatar
Craig ... did you ever take your 11 x 5 inch wheels off the car ?
VikingBlue is offline
Old September 13th, 2011, 12:18 PM
Land Yacht Captain
You mean I can't run wheels from a Mini Cooper?
455man
Wheels and Tires
43
June 13th, 2012 02:50 PM
cnewp000
May 28th, 2010 05:55 AM
Oldsmaniac
May 26th, 2010 10:18 AM
AZ442
October 31st, 2009 05:06 PM
gillbates
September 18th, 2009 10:57 AM
Quick Reply: Engine RPM at Highway speed??
