1966 425 crank/balancer bolt
I'm trying to remove the crankshaft from a 1966 425 that I pulled from a Toronado. The problem I've run into is that my whimpy compressor/air wrench will not spin loose the bolt that holds the balancer on so I'll need to take it to a shop for that help. I've taken a lot of motors apart and believed these bolts had standard direction threads, but this one has a large "L" in the head. I'm used to that meaning left handed threads. Before I ask someone to put a 3/4 air wrench on this I need to clarify that... can anybody confirm if its right or left handed threads for this specific motor?
John
John
Thank you for the suggestions guys. I made the mistake of stripping the motor down before breaking this loose, so now the crank is freely rotating without any real resistance. I'll try your suggestions before taking it to a shop.
John
John
Kurt, I've also used the "rope trick" before. You can do this when replacing valve guide seals.
If all else fails you can reinstall one head and put the bolts in "snug." Then you can use the "rope trick" to prevent the engine from rotating.
Actually, the problem with your impact wrench may be easy to fix. I recently had this problem. My ancient Craftsman impact wrench had been steadily loosing torque. It got to the point that it wouldn't even loosen the lug nuts on my dually. I unscrewed the air inlet fitting and there was a metal screen inside the fitting with a foam filter. The foam had deteriorated and gummed up, effectively restricting the inlet pressure. I removed the foam and the impact wrench works like new now.
steve walker
December 17th, 2019 12:32 PM
f-85
September 26th, 2012 11:18 AM
smcurro
January 28th, 2009 09:00 AM
Steve O
December 12th, 2008 09:22 AM
