71 W30 Auto Carb 4 speed in an A/T
Old September 4th, 2014, 06:21 PM
erw813's Avatar
To all those in the know, I have a 1971 W30
carb # is 7041253
1040
Am I correct that this correctly sits on a 1971 W30 4 speed drivetrain? If so, does this offer any benefit in terms of performance? Is it possible this might have come from the factory with this? body code build date is 03A
erw813 is offline
Old September 4th, 2014, 06:55 PM
442Harv's Avatar
That is not a W30 number. It is for a A.T., M.T 442,and 350 with M.T.
442Harv is offline
Old September 8th, 2014, 10:57 AM
paulolds's Avatar
That number was used on 442 with manual trans and 350 with manual trans. was also used on W30 with man trans. The other number 7041256 is considered to never have existed.
paulolds is offline
Old September 8th, 2014, 11:29 AM
rr69ho's Avatar
That cowl D/C coinsides with the D/C on the carb 1040 which would be the 2nd week of Feb.
Your car car being built the 1st week of March.
rr69ho is offline
Old September 8th, 2014, 11:50 AM
jensenracing77's Avatar
Originally Posted by paulolds
that number was used on 442 with manual trans and 350 with manual trans. Was also used on w30 with man trans. The other number 7041256 is considered to never have existed.
x2
jensenracing77 is offline
Old September 18th, 2014, 05:16 PM
Mr Shifty Sidney's Avatar
Curious about the 350 manual trans application for the 7041253. Is this documented?
Thanks,
Don W
Mr Shifty Sidney is offline
Old September 18th, 2014, 06:26 PM
paulolds's Avatar
Olds engine assembly manual for 1971 shows only one carb for manual transmission applications in a 4 BBL, that being the 7041253. There may have been a mid year change or supply chain issue as a friend had a 71 350 4 speed car with the 7041253 and it was original to the car. Others say only one carb was offered on a 350 regardless of transmission, that was the 7041250. The assembly manual confirms 7041253 was used with engine codes QB and QO.
paulolds is offline
Old September 18th, 2014, 06:54 PM
Octania's Avatar
"The other number 7041256 is considered to never have existed."
So, the SMW 403 of carbs?
Octania is offline
Old September 21st, 2014, 01:07 PM
Paul,
Do you know the build date on your friends 350 4 speed car? I agree with possible mid year changes. Olds seems to have had to rethink a few items on the 71's after start up.
Thanks for responding with detailed answer.
Don W
Old September 21st, 2014, 02:54 PM
erw813's Avatar
correction 7041258-1040
crrection to original post
erw813 is offline
Old September 21st, 2014, 03:34 PM
erw813,
Can you post a picture of carb numbers? I do not think Olds made a 7041258 carb in 71.
Could it be a 7040258? That is a carb from 1970 and it would fit with the 1040 date code. I interpret the date code as being built on the 104th(mid April) day of 1970. That seem very unlikely for a 71 carb.
Don W
Old September 21st, 2014, 06:27 PM
erw813's Avatar
Pic of Code
pic
erw813 is offline
Old September 21st, 2014, 07:02 PM
That looks to me to be a bad restamp.
Don W
Old September 24th, 2014, 05:34 PM
paulolds's Avatar
Carbs
Originally Posted by Mr Shifty Sidney
Paul,
Don W
I still have the original distributor from that car. We located the seized Motor in a field in Manitoba in 2002. Carb was gone but kept the dist. Date on dist is 0J9 which I read to be Sept 09 1970. The big Gm strike started a few eeks later, so I would say the Build date of thet car was Between Sept10 to Sept 26 1970.
paulolds is offline
Old October 9th, 2014, 03:51 PM
erw813's Avatar
Proper Date Code
Ok does anyone know the proper date code for the carb on a 1st week March 1970 build for a W30??
erw813 is offline
Vader
August 12th, 2013 08:27 AM
Vader
April 30th, 2013 11:42 AM
Vader
February 21st, 2012 06:29 AM
Daverd
February 24th, 2011 07:43 PM
Daverd
October 4th, 2009 01:42 PM
Quick Reply: 71 W30 Auto Carb 4 speed in an A/T
