1970 original oil filler cap???
Old May 13th, 2010, 07:58 AM
Lance
ROCKET VAPOR's Avatar
Which oil filler cap would be correct for a Fremont plant built 442 in late March of 1970???
Or... does anybody have some photos they could share of an original assembly line issued oil filler cap???
This???
Or this one???
ROCKET VAPOR is offline
Old May 13th, 2010, 04:15 PM
BlackGold's Avatar
I can't speak for the Fremont plant and how it might differ from others. But as far as I'm concerned, the top photo (ears on the side of the cap, not top of the cap) is the correct for 1970. That's what you see pictured in the assembly manual and chassis service manual, and that's what I've seen on original, unmolested cars.
I will mention, however, that I'm not sure if that exact part number, style of lettering, and crimping of the center thingy is correct. It all looks different than what I'm used to seeing, but I can't tell you why, off the top of my head.
BlackGold is offline
Old May 13th, 2010, 09:26 PM
O's_Car's Avatar
For what it's worth, my Cutlass S with 350 engine came out of the Fremont plant in May 1970 (happy 40th!) and has the cap shown in the upper picture.
O's_Car is offline
Old May 14th, 2010, 03:10 AM
BobsW32
Bobsw32's Avatar
I have several originals and they are the top photo.....
Several of our vendors out there are selling the bottom one as the correct item... I met with them at Seven Springs and they not the problem and are working on getting the correct item
Bobsw32 is offline
70Post
March 4th, 2015 12:09 PM
Theo's '67
June 7th, 2011 11:43 AM
ROCKET VAPOR
June 4th, 2010 05:49 PM
Cameo White
Hurst/Olds
15
April 29th, 2010 01:16 PM
68Tom
May 24th, 2009 12:53 AM
Quick Reply: 1970 original oil filler cap???
