Swapping steering column column shift to floor on '68
I know the '68 columns are one year only due to no key in ignition- are the columns from chevy chevelle or gto the same? Want to make sure I don't screw myself.
Any idea what a decent '68 tilt floor shift steering column sells for?
isn't the dash opening for the column smaller on the 68, so a 69 column wouldn't work .... without cutting the metal dash.
now the 68 column on a 69 idea I like.
as for 68 columns from other GM A-bodys, the ***** for the hazard flashers would be different, along with the turn signal arm. I suppose you could swap the olds specific items in place of the others and it would work.
This happens from time to time, how does a thread from years ago get renewed? When I long on here, I can’t see threads more than a couple days old unless I actually search thru the history. And with the traffic here, that would be a lot of history for a 6 year old thread to show up.
hvysupreme
February 18th, 2017 12:40 PM
Bitburger
December 30th, 2012 04:49 PM
Alocatelli
December 10th, 2012 07:49 AM
