Ss1
Old April 1st, 2014, 09:24 PM
Sammy70 455 Supreme
sammy's Avatar
Ss1
I have been thru all the rims in my shop and the only ones to fit properly on my 68 442 with dual piston calipers are the steel wheels.
Was there an SS1 made that will have the proper offset to fit these calipers?.....I like the look of the ss1 .........
Thanks,
Ted
sammy is offline
Old April 1st, 2014, 09:31 PM
2blu442's Avatar
I've got some 14X7 SSI wheels, I thought only the early 14X6 SSI wheels were drum brake only. Someone else will have to clarify, but I'm almost positive the 14X7 SSI, SSII and all sizes of SSIII will fit disc brakes.
John
2blu442 is offline
Old April 1st, 2014, 09:40 PM
Sammy70 455 Supreme
sammy's Avatar
Yea, I bought a set of SS1 14x6 stamped with a Nov 69 manufacture date......they fit the rear
sammy is offline
Old April 2nd, 2014, 04:59 AM
Old School Olds
tru-blue 442's Avatar
Ted, you will have to look for the LY
code wheels. 14X6 I believe.
Made for about 6 months in 69.
I had a set a few years back.
The code is by the valve stem.
Seems like they were full chrome wheels,
and not the ones with the paintable spokes.
tru-blue 442 is offline
Old April 2nd, 2014, 06:39 AM
Trying to remember member
wmachine's Avatar
Yes, sort of.
The 810 SSIs were introduced in April '69 and fit disc brakes. The code stamp is not by the valve stem, it is on the outer part of the rim on the *inboard* side of the wheel, presumably not to mess up the chrome finish.
None of the 14 x 6 SSI wheels have painted spokes. The spokes have a satin finish because the centers are bead blasted so the black inset paint will stick. Some early '66 SSIs do not have the satin spokes. It took a little time for them to realize the paint was not sticking!
FWIW, my '69 has disc brakes and came with those wheels.
wmachine is offline
Old April 2nd, 2014, 12:25 PM
Sammy70 455 Supreme
sammy's Avatar
So the LY code wheel 14x6 would be pretty hard to find ?
Would the dual piston caliper need more offset than a single piston?
The JL2 is a GOOD inch outside the rotor, with hardly any room between the caliper and rotor
I have the steelies and period correct wire hubcaps..just really like the look of the ss1 on the car
Is the LY code wheel the same as the rims that came with HO in 69?....
sammy is offline
Old April 2nd, 2014, 12:30 PM
Old School Olds
Ted, I believe the 69 H/O
wheel was a 15" SS-2...
I could be wrong. Kurt?
Old April 2nd, 2014, 02:38 PM
firefighter5174's Avatar
My 69 Cutlass has the ss1s that fit disc brakes. Ive been considering letting them go. Not sure what kind of price to ask if I do. They would be good drivers (one has curb damage and will need to be fixed). If I remember correctly all have minor pitting.
firefighter5174 is offline
Old April 2nd, 2014, 09:10 PM
Randy C.
rcorrigan5's Avatar
The 14X6 SSII (LS) wheels will fit the dual piston caliper cars. My niece's '68 with the dual piston calipers has these wheels.
Don't know if the LY code 14X6 SSI wheels will fit the dual piston calipers.
As best as I have been able to figure, the 14 X 6 LY SSI was made for only about 4 months - from early April 1969 to the middle or late July 1969 - which finally gave the buyer back then the option of having the SSI wheel with disc brakes. I've got a '69 4-4-2 that was a mid-May 1969 production with disc brakes and LY wheels. The other style of SSI wheels (LE, or 795?) only work with drum brakes.
Price for a set of LY wheels? Hard to say. Somewhat rare - yes. But what is the demand? Don't know.
I agree with Ted - I like the looks of the SSI wheel the best. Although my '68 with drum brakes originally came with steel wheels and wire wheel covers, I believe the car looks a lot better with the SSI wheel!
My first car, a'69 holiday, also had drum brake SSI wheels.
Randy C.
rcorrigan5 is online now
Old April 3rd, 2014, 05:26 AM
Sammy70 455 Supreme
sammy's Avatar
Great info here...thanks
sammy is offline
Old April 3rd, 2014, 07:35 AM
wmachine's Avatar
Correct
Yup! I believe prior to '68, the SSI wheels were *not* stamped with the Broadcast Code. In fact, there is evidence that in '66-'67 they did not even *use* a Broadcast Code for the SSI wheels.
Randy C.
There were definitely preferences for both. The SSIs were the universally liked 5 spoke design, and the SSIIs were a very unique and distinctive Olds wheel that became iconic for Olds. In '68 & '69, I'm sure Olds dealers did a lot of wheel swapping both ways before deliveries.
wmachine is offline
Old April 3rd, 2014, 10:34 AM
hookem horns's Avatar
Not the cheapest option, but you could get 15" Wheel Vintiques SS1 repro's that would open up a lot of tire options. Or find 1970+ SS1's if you like the trim ring look.
I'm not sure, but do the later single piston calipers change what wheels fit? If so, they are plentiful, simple and cheap if exact originality is not a concern.
http://www.summitracing.com/search/p...ed-slot-wheels
hookem horns is offline
Old April 3rd, 2014, 09:03 PM
I'll agree with the 810 series being the disc brake compatible ones, but mine are JK code, not LY. Dug one out of the closet to look at it.
And the later calipers work, as they're sitting in the closet too, on their spindles.
Koda is online now
Old May 3rd, 2014, 02:28 PM
Sammy70 455 Supreme
sammy's Avatar
just picked these up.
Need some help IDing them
M5/8 2 valve 8 NA
M= Motor wheel corp, plant 5
8=1968
2=Feb
8=8th day
NA=application code
Am I way off in the identification of these rims?
any help would be great!
sammy is offline
Old May 3rd, 2014, 03:10 PM
Old School Olds
Don't know the codes Ted.
They look like SS-3's.
Are they 15X7?
Old May 3rd, 2014, 03:50 PM
2blu442's Avatar
I agree, they look like the 1980's Hurst Olds wheels, SSIII 15X7
John
2blu442 is offline
Old May 3rd, 2014, 03:55 PM
2blu442's Avatar
One more thing, snap on center caps didn't start until 1975. 1968 would have bolt on centers.
John
2blu442 is offline
Old May 3rd, 2014, 06:53 PM
Octania's Avatar
"M5/8 2 valve 8 NA
8=1968
2=Feb
8=8th day
NA=application code"
I'll vote incorrect on the above
The center cap stays on via spring clips in the squared off recesses of the center hole, and that was certainly not done in '68- not until at LEAST 1973. Someone has probably decoded the stampings on wheels, maybe for Chevies?
The "right" wheels for my '68 were stamped 695C I believe, and it took a while to find a set. They fit the manual DRUM brakes my car was provided with at the factory. I hear that the later SSI 14" all chrome [trim ringless] wheels could fit dish brakes, not sure what their stamping is.
The Supercars Unlimited catalog had a nice little chart of sizes, stampings, and fitment- maybe you can find that.
Octania is offline
Old May 3rd, 2014, 07:35 PM
The only SSII wheels available in 1968 were 14x6 with bolt-on centers, and they were NOT chrome plated, so I also vote "no" on your "decoding". As noted, snap-in centers are 1975-up, and chrome plated disk stampings were 1980s. The trim ring is not correct for an Olds wheel.
joe_padavano is offline
Old May 3rd, 2014, 07:54 PM
Sammy70 455 Supreme
sammy's Avatar
Thanks for the input...much appreciated!
sammy is offline
Old May 3rd, 2014, 08:18 PM
Sammy70 455 Supreme
sammy's Avatar
I was decoding the rim based on what I had learned on decoding steel wheels...I guess it is not the same.....that is what was messing me up with these rims....
sammy is offline
O's_Car
December 12th, 2016 11:17 AM
67442HT
April 9th, 2012 09:10 PM
jonstringer
May 12th, 2008 09:11 PM
fearthisrocket
February 18th, 2008 06:09 AM
Kennybill
October 3rd, 2006 05:37 PM
Quick Reply: Ss1
