Camshaft specs
Old September 2nd, 2021, 01:42 PM
Ontario69Hurst's Avatar
Camshaft specs
Since Oldsmobile always listed their cam duration specs at 0.000 and most manufactures list duration at 0.050 can anyone advise on comparable duration specifications for
the 285, 308, and 328 cams.
Thank you
Ontario69Hurst is offline
Old September 2nd, 2021, 02:32 PM
anoldsman's Avatar
The "194" 308 cam is 232 @ 0.050" intake and exhaust with 0.296" lobe lift on a 113 lobe separation. If you have any of the 285 or 328 factory cams, I'll gladly check them for you.
anoldsman is offline
Old September 2nd, 2021, 03:56 PM
Gary
VC455's Avatar
Here's specs I got at a factory seminar in the early 1970s. There's a slight difference from anoldsman's numbers but either of our versions is enough to help you make your comparison.
285° advertised (part 400165) 220/222° at 0.050"
308° advertised (part 402194) 234/234° at 0.050"
328° advertised (part 402169) 244/244° at 0.050"
VC455 is online now
marklt
April 23rd, 2015 06:11 PM
ericsolds
October 7th, 2012 12:29 PM
nonhog
July 7th, 2009 11:26 AM
Mike Hathaway
March 23rd, 2005 08:12 PM
Quick Reply: Camshaft specs
