Camshaft specs
Camshaft specs
Since Oldsmobile always listed their cam duration specs at 0.000 and most manufactures list duration at 0.050 can anyone advise on comparable duration specifications for
the 285, 308, and 328 cams.
Thank you
Thank you
Here's specs I got at a factory seminar in the early 1970s. There's a slight difference from anoldsman's numbers but either of our versions is enough to help you make your comparison.
285° advertised (part 400165) 220/222° at 0.050"
308° advertised (part 402194) 234/234° at 0.050"
328° advertised (part 402169) 244/244° at 0.050"
