"67" 442 Quadrajet
Old June 21st, 2021, 01:09 PM
NETSON1's Avatar
"67" 442 Quadrajet
If I were to get a replacement carb for 1967 442, Should I just Chevy style inlet? To the side and not straight on. The issue is a stripped out filter housing thread.
All searches of JET models call for a Buick/Olds version with straight inlet.
NETSON1 is offline
Old June 21st, 2021, 01:16 PM
Randy C.
rcorrigan5's Avatar
Your filter housing thread can be repaired through a heli-coil process. I've had it done on the original carbs for m '68 and '69 and it's worked beautifully.
Randy C.
rcorrigan5 is offline
Oldsmaniac's Avatar
The correct 67 442 carb had the side facing fuel inlet....and the divorced choke. Somewhere around 1970 the quadrajet for the Olds switched to a straight fuel inlet.
Oldsmaniac is offline
Old June 21st, 2021, 01:36 PM
therobski's Avatar
Those inlet housing Q-jet re-thread kits are available..Fact I got 1 sitting out in the garage never used...
therobski is offline
Old June 21st, 2021, 01:44 PM
therobski's Avatar
here you go
Old June 21st, 2021, 03:31 PM
1968, actually.
joe_padavano is offline
Originally Posted by therobski
here you go
Yeah, and you get to use those exactly one time.
Old June 21st, 2021, 03:36 PM
To the OP, the original 1967 carb was a side inlet, just like a Chevy. The correct carb number for a 49-state 442 was 7027156, and for Calif cars with A.I.R. it was 7027157.
Old June 21st, 2021, 03:41 PM
therobski's Avatar
X2 yep! Each one has a different size inlet for the fuel line from the pump. I guess depending which Q-jet your going to mend...Have not seen any for the earlier Rochester 4-jets...324, 371-394's etc..
Old June 21st, 2021, 06:57 PM
NETSON1's Avatar
Ok great. Thanks for the confirmation. I have extensive experience with big and small aftermarket Chevy builds but not much with Olds, which really is my favorite though. Ive had a few over the years but couldn't seem to hold on to them cause of the expensive parts! Had a 68 455 Delta Custom and a 67 Turnpike Cruiser. There was too much deep engine work and I couldn't keep up.
This 442 is in great shape cosmetically but has a lot of the same problems, crappy idle , likely due to mangled exhaust seats and worn out Q-Jet. The cylinder pressures in this 10.5-1 400cu in.
motor are all around 175psi.
Does that seem halfway decent to you guys?
NETSON1 is offline
Old June 21st, 2021, 08:43 PM
edzolz's Avatar
Those are not the same as an "heli coil" repair. That is a one time "repair" that possibly will ruin your Q-Jet.
edzolz is online now
ronbo97
September 28th, 2018 07:56 PM
jonesolds442
June 20th, 2016 06:49 AM
ScottM47448
December 16th, 2012 07:18 AM
Giddy
September 16th, 2011 07:12 AM
68Tom
December 7th, 2010 03:19 PM
Quick Reply: "67" 442 Quadrajet
