1968 442 W-30 'vert
Old October 12th, 2009, 11:40 AM
68Tom's Avatar
1968 442 W-30 'vert
Any one see this? Pretty nice. Interesting color/stripe combo.
http://cgi.ebay.com/ebaymotors/Oldsm...item33565d4ad1
68Tom is offline
Old October 12th, 2009, 12:26 PM
Diego's Avatar
Striping is not correct.
Diego is offline
Old October 12th, 2009, 07:26 PM
Originally Posted by ebay
...and is factory correct in every way
Where to start?
I can't tell from the pictures what color the W-36 stripes are supposed to be. The only available stripe colors in 1968 were black, white, gold poly, orange, red, and buckskin. I guess they are supposed to be gold?
The 1968 cars did not use the W-30 decal on the front fenders. There was no "genuine hardwood" steering wheel available from the factory - it was plastic. Disk brakes were not available on the W-30 that year, PARTICULARLY with a drum brake master cylinder!
Of course, this is a fully optioned car. Again, when have you ever seen a body-off resto that wasn't. How many of the options were added during the resto?
I will say that the red inner fenders appear to be originals, not repros. On the other hand, it is not the original engine. Once again, without documentation, one has to question if the car is real or fabricated.
joe_padavano is online now
Old October 12th, 2009, 08:09 PM
Diego's Avatar
Joe, do you mean power disc brakes were not available?
Diego is offline
Old October 13th, 2009, 06:58 AM
No, I meant what I said. DISC brakes of any flavor were not available on the 1968 W-cars. Manual drums were the only option. Scary? Yup!
Old October 13th, 2009, 08:06 AM
Diego's Avatar
Joe, I just looked at my information and it shows that non-power discs were available. However, I also have a bulletin dated 9-19-67 that says option JL6 has been cancelled for all A-bodies. Whether it was reinstated is a different story, as I don't seem to have any docs that suggest such a thing.
So, perhaps, it's more accurate to suggest that non-power discs were not available AT ALL on all 4-4-2s?
Diego is offline
Old October 13th, 2009, 08:18 AM
I'm afraid you've gone off in the weeds here. My whole point was to state that the ad claims that the car has disc brakes (despite the drum brake M/C in the picture). The 1968 W-30 was ONLY available with manual drum brakes. I was not intending to make a statement that covered any other type of car EXCEPT the 1968 W-30. Again, my original statement is correct.
Old October 13th, 2009, 08:43 AM
Diego's Avatar
Well, I think when it comes to 1968 W-30s, don't you think there's a few options that were not available due to the cam? I inferred that the discs not being available was an incompatibility issue with the W-30 package when the truth may be that no manual discs were available for any F85 regardless of engine - see my point?
Diego is offline
Old October 13th, 2009, 10:29 AM
is Fast Enough ...
mugzilla's Avatar
Where to start?
ram air , 12 bolt, ...
mugzilla is offline
Old October 13th, 2009, 10:40 AM
Huh?
Old October 13th, 2009, 11:01 AM
is Fast Enough ...
mugzilla's Avatar
Let's start with the terminology in the add ...
rolleyes for the seller ...
mugzilla is offline
Old October 13th, 2009, 11:10 AM
Ahhh. Got it.
Old October 13th, 2009, 03:25 PM
Diego's Avatar
I emailed him last night. Almost 24 hours and no reply . . .
Diego is offline
Old October 13th, 2009, 06:36 PM
Trying to remember member
wmachine's Avatar
I find the sidetrack through the weeds to be interesting. I would speculate, given the 9/19/67 date of the discontinuation, that the power disc brakes never made it to production, and the bulletin simply was officially putting it to bed. This was Oldsmobile's first attempt at non-power disc brakes and I would guess they ran into problems they couldn't resolve at the time.
wmachine is offline
Old October 13th, 2009, 09:56 PM
is Fast Enough ...
mugzilla's Avatar
probably a dual cyl like pontiacs 68 disc which lasted one year to be replaced by a single cyl ...
mugzilla is offline
Old October 14th, 2009, 04:56 AM
wmachine's Avatar
Yes, the '67-'68 Olds disc brakes used the dual cylinder, and went to the single piston in '69.
But that wouldn't itself be the problem as they continued to offer the *power* disc brakes. What was cut off was the *manual* disc brakes.
wmachine is offline
Old October 14th, 2009, 02:58 PM
I remember reading someplace (and unfortunately I don't remember where) that Olds engineers did not believe that there would be sufficient braking force in the disc brakes without the power booster. Keep in mind that drum brakes are self-energizing, discs are not. Since the W-cars didn't provide enough vacuum for power brakes, manual drums were the only option.
I wonder what changed their minds. My 70 W-30 has manual disc brakes and I have no problems stopping the car. I wonder if this change is related to the switch from the four piston calipers to the single piston sliding calipers. (Wasn't there some documentation that showed the manual disc brakes available on the 1969 W-cars?)
One possible theory (and it's only a theory) is that the switch to the sliding calipers reduced the fluid requirement for the front brakes, which enabled the use of a manual master cylinder.
Let me explain a little further. First, to increase brake hydraulic pressure without increasing required foot pressure, you reduce the diameter of the master cylinder piston. Unfortunately, with a smaller diameter piston, you need to travel further to displace the same amount of fluid. The four piston calipers had two design features that require a larger amount of fluid than the single piston calipers. First, the four pistons have more surface area than the single piston. This is good for braking force but it means that more fluid is required and thus more pedal travel on the master cylinder. Second, the sliding caliper follows any warpage in the rotor, but the fixed four piston calipers do not. Any rotor runout pushes the pads away from the rotor, which in turn push the pistons back into the caliper. That means that additional brake fluid volume is required to make up this "knock-back". It's possible that the manual version of the master cylinder, with it's smaller bore, just couldn't provide enough fluid under all conditions.
Old October 15th, 2009, 07:45 AM
junior supercar's Avatar
from what I understand, manual disc for the 67/68 dual piston setup couldn't happen because enough force couldn't be applied to sufficiently and safely use the setup. Pretty much what you are saying Joe.
Now for 69, at least for the W-31s, I have yet to locate a documented manual disc brake car. There was one built since it was in a magazine road test back in the day (don't have the issue off hand now), but as far as I've been able to determine all 69 W-31s are manual drums.
junior supercar is offline
Old October 15th, 2009, 08:13 AM
Diego's Avatar
Chris, do you think it's possible that the magazine listed the option but it was not correct? I can think of a road test where they listed gears that were not available from the factory.
Diego is offline
Old October 15th, 2009, 08:56 AM
Magazine road test cars were often one-offs or pre-production cars.
Old October 15th, 2009, 09:05 AM
Diego's Avatar
But, for example, a Ram Air IV GTO should not have 3.55 gears. The stats were either written wrong, the car was instead a RAIII, or the GTO was a turkey. Considering Pontiac was pretty tight with their press fleet, I seriously doubt the latter.
Diego is offline
Old October 15th, 2009, 06:05 PM
March 1969 Car Life is the mag with the 69 W-31 road test. Basically what the article says is while this tester has the manual discs, the engineers weren't sure if it would make it into production.
Old October 15th, 2009, 07:32 PM
agtw31's Avatar
this guy has been trying to sell this car on ebay for at least 6 or 7 years,unless this is the latest sucker.
agtw31 is offline
Old October 16th, 2009, 02:16 PM
Old Time Old's Fan
mtwalet's Avatar
My brother has been in touch with the current seller. The seller is not the owner.
This car was sold at Barrett-Jackson's 35 Anniversary at Scottsdale in 2006. Before that it was sold at Barrett-Jackson's Palm Beach auction in 2005. There is absolutely NO documentation to verify this as a W30 car. Although that doesn't rule out that it isn't. The seller can't really prove it is, and no one can say for sure that it isn't. It may be a dealer installed W30 option. I don't know if the car underwent a full restoration or not. It doesn't appear so. If the car was repainted and a frame-on was done, it's possible the build sheet is still in tact within the car(??)
So if you sit back and think about it, at best what would a nice 442 4-speed convertible with all those nice options be worth? Not cheap I am sure.
I just think if the seller cannot prove it is a W30 car, it should not be advertised as a W30 car.....regardless of what equipment and W30 'stuff' may be on the car. I'm surprised Barrett-Jackson would allow an undocumented car to cross the block. Reputation you know.
My brother and I may possibly go look at this car since he has been looking for a nice 68 442 4-speed convertible for quite sometime and the hunt goes on.
mtwalet is offline
Old October 16th, 2009, 02:19 PM
Diego's Avatar
I am not so concerned with the lack of documentation and the W-30 claims being made. I'm more concerned with the claims about how it's completely stock and perfect when others have pointed out there's a lot of glaring errors.
Add to this an unresponsive owner (eBay) and it makes me think he's looking for someone to take advantage of.
Diego is offline
Old October 17th, 2009, 01:23 PM
HAHAHAHAHA
That's funny!
Old October 17th, 2009, 02:11 PM
Diego's Avatar
If they are not liable, they won't care.
Of course, if they cared regardless of liability, it would help their reputation in spades . . . but they're making money hand over fist, so why change?
Diego is offline
Old October 17th, 2009, 02:34 PM
4fortwo's Avatar
And who documented BJ ever sold the car?
4fortwo is offline
Old August 6th, 2011, 04:11 AM
mongotz's Avatar
1968 W 30 disk brakes were manual because engin did not creat enough vacumm
mongotz is offline
Old August 7th, 2011, 10:24 AM
1968 W-30 disk brakes were NONEXISTENT since only manual drum brakes were offered that year.
Old August 10th, 2011, 03:05 PM
  #31
dsa2207's Avatar
Joe is correct, period. Same goes for 1969, period.
dsa2207 is offline
Old August 10th, 2011, 06:33 PM
  #32
Actually, there are documented 1969 W-30s with manual disc brakes. Apparently this was a mid-year addition.
Old August 10th, 2011, 06:45 PM
  #33
dsa2207's Avatar
I've never seen one.
dsa2207 is offline
Old August 17th, 2011, 05:22 PM
  #34
I've seen a few. fwiw
ctosiflying
Body work
September 21st, 2014 12:26 PM
Mr.Smooth
December 10th, 2013 11:05 AM
halfmoontrail
March 17th, 2013 10:28 AM
truck5513
November 4th, 2012 05:43 AM
OLDSRALLYE350
November 27th, 2009 08:19 PM
Quick Reply: 1968 442 W-30 'vert
