Click Here
Looking for SSIIs
Old May 9, 2014 | 12:11 PM
Earls63304's Avatar
Looking for SSIIs
I have a 1973 Cutlass S with a 403.
Looking to go to SSIIs with the trim rings etc. then color match them to the car -- Can anyone make a recommendation and source for parts?
Also whats the best size 14x? or 15x?
Old May 9, 2014 | 12:15 PM
15" for sure as the tire selection in 14" is very limited.
Factory wheels would be 15x7 but if you go for the aftermarket wheels, why not get 15x8 so you can use a wider tire if you want - those 403s make a lot of torque and can be hard on skinny rear tires.
edit:
Oops, I see you want to match the vehicle color, so factory wheels are the only choice. If you want 8" or wider, then you could use 14x6 or 14x7 wheels and have the centers cut out and welded into 15" blanks in 8", 9", or 10" width.
Old May 9, 2014 | 03:18 PM
Be aware that if you go to SSII/III wheels, you will not be able to upgrade the brakes as you are looking to do in your other thread. Even the 15" SSII/III wheels will only clear the stock 11" rotors.
Old May 10, 2014 | 04:48 PM
CRUZN 66's Avatar
Olds Fever
I had a 73 442 which came factory with 14x7 as well as a 73 Cutlass Supreme which also had 14x7.......
Old May 10, 2014 | 04:57 PM
Both 14x7 and 15x7 were factory-available in the 1973 model year.
Old Jun 1, 2014 | 07:53 PM
Earls63304's Avatar
I found a set of 4 - 14x7 SSIIs for sale with center caps for sale for $250 - Seems like a good price. The add says '14x7 for 1970-72' and the wheels have a stamp on them that reads 14x7 JJ with what looks like an upside down '7' then 88 (before the size). So, my questions is.......will these fit my 1973 Cutlass S (with my std. front disc and rear drum)?
Old Jun 1, 2014 | 08:12 PM
2blu442's Avatar
Yes. If they have bolt on center caps (which 70-72 would have had) then those would be identical to the 14X7's that were available for your car in 1973.
John
dads72
Feb 9, 2015 08:52 AM
stevengerard
Wheels and Tires
31
May 30, 2012 11:49 PM
z11375ss
Wheels and Tires
Mar 29, 2011 04:53 PM
chocolate apocalypse
Wheels and Tires
Jun 9, 2010 08:14 AM
chris83
Dec 28, 2009 04:38 PM
