SS2 15X7 Trim Rings Needed
If you would like to have (3) extra center caps just in case...
https://classicoldsmobile.com/forums...nter-caps.html
I was going to just go with one for now until I decide if I'm keeping these rims in the long run or not . I will definetely buy the ones from you if I decide to keep the rims I have on the car now . The ones you have are real nice .
Ummmm , how about an manufacturer part number ? Sorry , I'm getting pissed off on E-Bay because people are listing trim rings without listing what make of car it actually fits on .... am I missing something here ? MY KINGDOM FOR TWO TRIM RINGS
edit ... It looks like there are deep dish ones ???? Is this what I want ? I noticed that there was a conversation on OP about this which left me understanding absolutely nothing . Grrrrrrr
The trim ring below was the only one I seen for Olds in the link you gave me , and it doesn't list a rim size . It also looks like the middle part runs to steep for my rims . I'm not sure , I may have to call them . Thanks again .
edit .... as a matter of fact there is a difference where the valve stem sticks through too , comparing to the picture of mine that I have above .
Fusick's makes a decent stainless steel reproduction. About $60 a piece, I think. Either 14's or 15's. They're about 3" deep. Also can find some made from chinesium on Ebay, but the profiles vary alot.
ok it looks like they may have some in the JaeEagle link . I didn't see that one . I would have to buy four , and it would be about a hundred bucks
. I was hoping for two used ones for a whole lot cheaper
. I may have to wait and get some patience I guess .
BTW ... I will let you know what I'm gonna do about the tire situation soon . I'm stuck in a dilema now helping out some chick at my work with her car this weekend .
I also have my car to work on at the same time , and now my STUPID wifes car sounds like it has an issue too . I may be fixing cars for awhile ..... yay .
. BTW ... I will let you know what I'm gonna do about the tire situation soon . I'm stuck in a dilema now helping out some chick at my work with her car this weekend .
MY KINGDOM FOR TWO TRIM RINGS ! Actually your gonna have to settle for my apartment lol . Someone said they are the three inch ones ? I'm not sure where that measurement derived from since there is nothing on the trim ring that is three inches that I measured
You can find so-so trim rings all over for cheap if you're just looking for something to look ok. Do you have swap meets in your area? That's where you'll find lots of cheap parts. (Of course mostly for chevies) Anyway there is a "correct" trim ring specifically for your SSII's but almost any 15" trim ring will work. You can also go to a used hubcap place and get some. I have a 71 Cutlass that I put 15" SSII's on and looked for a set of perfect trim rings to buy, couldn't find or way too pricey. Then over the years I just bought 1 here and there and replaced them as I got better ones. I still go thru all the trim rings at swap meets.... Good luck. Oh you can find caps there too.
I guess I didn't have it worded right or something . I found these right away this morning , but they're 4 " rings . Will they still work ? It says they are for 15 X 7 rims ....
I started a thread here a long time ago about this, it is very difficult to find the "correct" trim ring but as some have mentioned there are numerous ones out there. I do believe 4 inch will be too deep. But in reality any of the 3" or 3.5" will work. yes they have different angles and different valve stem openings (some round some oval) but as you said few will be able to tell the difference once mounted. You should be able to find used ones around you.
I Found A Set !
I found a set of four for $69 off of E-Bay . It has a return option , but I know these are right . This includes shipping , and they are exactly alike . Polished Steel .
oldsguybry, did you buy those $69 trim rings off ebay? If so were they any good?
I bought some similar ones off ebay for about that price. They looked pretty good, fit good, but after some usage developed a slight brownish hue to them like brake dust after you just cleaned them and then drove for 1 day. By themselves they were fine but i then got some OEM ones (40year olds) and next to the OEM ones the ebay ones defintely have a less than great chrome look to them. the OEM chrome is "whiter" if you will.
heres a pic when I first got them ...i cant be sure if they have the brownishh hue in this pic, but they look like a thin brake dust coating that would not clean off.
trim rings
Just got new trim rings(from above ebay seller) to put on my newly aquired 15" rims. Seems the rims aren't that deep compared to my original 14" rims. Is this the way its suppose to look? Not really happy with it. Thanks for any replies.
Hey Tom . From what I remember there are different depth rings available . That was one of the problems I had trying to find mine . I had to eyeball pictures of rings online to determine which one I needed . It didn't seem there was any concrete explanation on how to determine which one you needed either . I have the 15 x 7 SSII rims if this helps . The ones I bought are pretty flimsy compared to the originals and they were a PITA to install
@tom
The ones in the above pic are ebay ones, I will sell them $50 shipped in the us. They look ok but IMHO they aRe not as nice as the originals. I replaced those w some decent original ones , I like them much better, I'll post a pic of them later, despite having some wear to me the originals just look nicer.
The ones above and the originals go tight to the edge of the d ring there is no gap.
He's right , the originals are better . The polishing on the ones I bought don't look the same and they are flimsy . Not to mention they were impossible to put on until I bent all the tabs in . I kept two of the original rings on my car because they were in decent shape yet .... from 10ft you can't really tell the difference
The ring in your pic look to be the more flat Chevy rally style. The Olds rings have a wider lip and have more of a curve to the large flat area. The rings that RR pictured look a lot more like the Olds originals.
Is there anyway to identify the original 15" trim rings? Are there part numbers on them?
I have real trouble paying money for trims rings that chances are they don't look right or should go right into the garbage because they confuse the issue.
I'm assuming they need to 3" deep for a 15x7 is that also correct? Thx.guys.
