Click Here
Need Advice on Which Rims?
Old October 5th, 2018, 08:46 PM
pettrix's Avatar
Going on a 72 Olds 442 convertible (rears):
Jegs 15x10 aluminum rim, load capacity of 2,100 LBS per rim and they weigh 21 lbs per rim and cost $112 per rim
Jegs 15x10
OR
Billet Specialties aluminum rim, load capacity of 1,200 LBS per rim and they weigh 16 lbs per rim and cost $365 per rim
Billet Specialties
Any advice/comments?
pettrix is offline
Old October 6th, 2018, 04:32 AM
You need to be close to 5" backspacing for a 15x10.
oldcutlass is online now
Old October 6th, 2018, 06:48 PM
Mr Nick's Avatar
They are available in 5.5" backspacing, which is better than the 6.5" you had listed.
https://www.jegs.com/i/JEGS/555/66185/10002/-1
Remove the JEGS logo off the center cap, and you have a sharp wheel at a great price.
Mr Nick is offline
Old April 26th, 2019, 09:31 PM
pettrix's Avatar
Will a 17" rim fit a 1972 Olds 442 convertible?
pettrix is offline
Old April 27th, 2019, 04:56 AM
Yes
Old April 27th, 2019, 07:38 AM
Rodney
cdrod's Avatar
Pettrix:
I have 18x9" rims with 5.25" backspacing on the back of my 442 convertible. The tires are 285-40R18 with 1.5" of clearance to the frame rail. I have the body off the frame at the moment so no pics on the car.
cdrod is offline
Old April 28th, 2019, 10:55 AM
The diameter of the RIM is irrelevant. The outside diameter of the TIRE is what matters.
joe_padavano is offline
Old April 28th, 2019, 10:38 PM
pettrix's Avatar
I like the taller sidewall profile tire on these cars. I don't like the large rim with a short sidewall. They just don't look good on these cars. Newer cars, yes but not the older muscle cars.
The 15" rim size has a limited amount of tires available as that size is kind of outdated with modern cars.
The 17" rims look good with a 50 series sidewall tire.
pettrix is offline
Old April 29th, 2019, 04:09 AM
gear head's Avatar
I would always go for the lighter wheel. Less rotational mass..
gear head is offline
Old May 1st, 2019, 10:19 PM
pettrix's Avatar
Although you need enough tire to be able to hook and connect on the road through turns. 295 or 305 width is usually needed even with drag radials for a 400HP+ engine. Hence the whole "big tire" vs "small tire" races they have on Street Outlaws.
pettrix is offline
Levellord
Wheels and Tires
November 19th, 2016 06:29 AM
oldsmobiledave
October 9th, 2015 01:58 PM
4424me
Wheels and Tires
March 19th, 2012 08:20 PM
Rolds72
Wheels and Tires
March 13th, 2012 03:26 PM
D Appeldorn
January 12th, 2011 06:01 AM
Quick Reply: Need Advice on Which Rims?
