Click Here
Will tires rub?
Old Jul 29, 2010 | 03:42 PM
scrappie's Avatar
Will tires rub?
I can get BF Goodrich 235/60/14 for my 71 442 conv. Has anyone ran the same size tire and had any problems with clearance?
Old Jul 29, 2010 | 04:18 PM
BlackGold's Avatar
You should have no problems with clearance with that size -- because they're too small!
They are no wider than the original tires, really. But at 25.1" in diameter, they are about 1-1/2" smaller than the originals. I know some people like this size, but I feel it looks way too small in the wheel well. If you want to run 60-series tires, go to a 15" wheel.
Old Jul 29, 2010 | 05:15 PM
jeffu231's Avatar
I run the 235/60 on a 15 inch rim on mine. Ends up being the same size as original 14's and looks better.
Old Jul 29, 2010 | 05:21 PM
MJAKS462's Avatar
I have 285/60 15 inch and there is lots of room to spare.
Old Jul 30, 2010 | 02:03 AM
scrappie's Avatar
I am looking to replace the tires I have because of dry rot. The car is not mint by any means so I'm just looking for the cheapest raised white letter tires that will fit my 14" rims. I cant find any online and was wondering if I stayed with 14" rims, what would be my best solution?
Old Jul 30, 2010 | 03:21 PM
BlackGold's Avatar
Go to the sponsors of this forum:
http://www.tirerack.com/tires/tires....RWL2&tab=Specs
BF Goodrich Radial T/A is a good, inexpensive, raised-white letter muscle car tire. Size P225/70R14 is closest to your car's original tires.
Old Jul 30, 2010 | 06:02 PM
scrappie's Avatar
Thanks for the info.
zodiacblueS
Aug 23, 2011 06:09 PM
old-olds
Jul 2, 2011 06:38 PM
old-olds
May 10, 2011 05:54 PM
Mike77
Body work
Jun 6, 2010 10:52 AM
WiSeGuY
Suspension & Handling
May 24, 2009 06:34 PM
