Click Here
Wheels & Tires
Old Feb 19, 2017 | 04:13 AM
CuttyLuv's Avatar
Wheels & Tires
Newbie here. Looking to put new wheels on my 72. Want to put 18's all around but a little wider in the back. Its a fastback style so I would like the rears wide enough to fill in the rear fender but without any rubbing of such. Also plan to top it off with maybe a 1 in. 1.3in drop to give it a nice stance. Advice for tire size would be much appreciated also. Thanks!
Old Feb 19, 2017 | 04:38 AM
I moved your post to the wheel and tire section. Welcome to the site, there are a few 18-19" wheel and tire combo's in this thread.
https://classicoldsmobile.com/forums...ost-yours.html
Old Feb 19, 2017 | 07:32 AM
anthonyP's Avatar
My suggestion, I would go with 15" rims all around with 225/70-15 in front and 255/60-15 out back to help fill out the fender wells. The slightly taller rear tires will give it a period stance look without changing the factory suspension, without sacrificing ride or worrying about pot holes, speed bumps, and other similar road conditions.
Old Feb 19, 2017 | 07:53 AM
oldsmobiledave's Avatar
error
FYI
225 70 15s are 27.4" tall
255 60 15s are 27.0" tall
The rear tires that you suggested are SHORTER than the fronts.
Old Feb 19, 2017 | 09:47 AM
anthonyP's Avatar
Originally Posted by oldsmobiledave
FYI
Oops, thanks Dave for the correction. I was thinking about the 275/60-15 tires in the back, which I believe are taller then the 225/70-15. From what others have noted, they fit without rubbing the rear fender wells.
jnaarnold
Sep 12, 2017 08:09 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
Wraythe
Feb 20, 2012 10:06 AM
olds70supreme
Oct 29, 2010 12:23 PM
cutlass47
Paint
22
Sep 6, 2009 07:23 PM
