Click Here
Wheel code help
Old Apr 25, 2017 | 02:30 PM
olds455's Avatar
Wheel code help
Hello, I have two 15x7 ss2(or 3) on the back of my 1970 cutlass with two 14s in the front. I have one third 15in wheel and it's data info is on the inside of the wheel where as the other two the data is on the back side. Are these the same wheels, maybe a different year? Any info would be great. I would like to match a set as I need new tires as well. Thanks
Old Apr 25, 2017 | 05:44 PM
I'm not really sure what you're asking. The 15x7 SSIII snap on center cap wheels are all the same, no matter where the data is stamped.
Old Apr 25, 2017 | 05:54 PM
olds455's Avatar
Ok that's what I figured based on the research I've found. I'll check the caps on the car now and go from there. Thanks
Old Apr 25, 2017 | 08:18 PM
hurst68olds's Avatar
M5/6 VS. M5/7
M = Motor Wheel Corp.
5 = plant #5 (Chatham, Ontario)
6 = 1976 & 7 = 1977
war eagle
Sep 12, 2015 04:28 PM
ros6872
Aug 28, 2012 09:53 AM
Boldsmobile
Nov 2, 2011 06:02 PM
rrielley
Feb 9, 2008 10:43 AM
OldsMotion
Mar 15, 2007 07:45 PM
