What size are my rims
The bolt pattern is 5 x 4.75 and factory rims are 14x6, 14x7 and 15x7. The only worries you will have is if you are looking at 14" or 15" rims as they may not clear your brakes but you are probably looking to go bigger. You will also need to know the offset and backspacing of the rims you are looking to buy to determine if they will fit in your wheel wells and if any issues with rubbing. If you search there are some threads on measuring and understanding the other measurements.
Second, any 14" wheel made since about 1972 with the correct offset will clear factory disc brakes on an A-body. Clearance is only an issue if you are using 1960s factory drum-only wheels, or similar vintage aftermarket wheels.
I've got a decet understanding about offset an backspacing I just dont want to end up buying the wrong rims, I have rear drums on it so I assume that after I go to a certain diameter rim it should clear no problem right?
What size are you thinking about getting? Usually the drums on the rear are not the problem it's the front disc brakes. If you want to stay near stock, 15" rims are safe option as they will clear the stock size disc brakes. Also 15" wheels have a bigger selection of tires than 14".
Well, the OP didn't indicate if he was looking for factory or aftermarket wheels, and there are MANY more aftermarket FWD wheels today than RWD wheels (unfortunately). Also, 14x7 aren't the only 14" wheels that clear factory disks. The 14x6 SSII wheels came on factory disk cars in 1968-69, for example. I'd be willing to bet that most 1967-72 A-bodies with disk brakes came from the factory with 14" wheels.
For the record I'd agree that the vast majority of 72 or earlier cars equipped with factory disc brakes did have 14" wheels. That was pretty much the standard wheel size back then, but the majority of those cars also came with drum brakes, making the 14x6" wheel the more common size.
cutlassclay - Stock 14x7" or stock 15x7" GM wheels will be a straight bolt on to your car. If you choose to go with an after market rim, check with the manufacturers application guide to see if it will be right for your car. Most shops will let you see the wheel on the car without bolting it up to determine if the look and offset will work for you.
Keep in mind that if you go with larger rims (16,17, 18" and rubber combinations) you may need to change your speedometer gear to get the right speed reading. The speedo gear is based on overall tire/wheel height and rear end gearing. Good luck with your project.
It might be time to back off on the caffeine a little...
