Tire pressures
Tire pressures
The owners manual for my '66 Toronado shows the tire pressures at 24-26 PSI. Is it just me or do these numbers seem low? Just wondering if the pressures were this low due to the tire construction at the time or something? Like, should I run higher px #'s with modern tires?
Those numbers were for 'Bias Ply' tires that came equipped on the car when it was new. The recommended tire pressure is found on the sidewall of all tires. It can vary depending on the size, type and manufacturer and your own personal taste. Just don't inflate them beyond the recommended maximum pressure and always check the pressure and inflate them when they are cold (not driven on). But generally Radial tires air pressure is much higher. I wouldn't want to give you a set figure and it be higher or lower than what's on your vehicle and cause your tires to wear out prematurely or even worse explode.
Yes, the low to mid-20s PSI recommended back in the '60s was both for bias ply tires AND to make for a softer ride. Things are different with radials. I run 30 to 32 psi on all of my old car tires now. Gives just the right amount of radial tire bulge.
With regards to the AC/Non-AC.......great question. The '66 CSM is full of interesting things in the Toronado section that are inexplicable. I guess it's just the typical first year stuff. I should really grab a '67 CSM just for comparison sakes and to see if they updated the silly stuff like that.
For recommended pressures, they're even lower. and no distinction is made between "average" and "full" load. For both situations, its front 24 psi, rear 22 psi.
The chart on tire size for A/C vs. non-A/C is identical to what you show. 8.85-15 T-FD for both situations. So, again, what's the point of the chart?
Keep in mind that in the 1960s, recommended tire pressures were intended to provide the best ride, not the best mileage or even tire mileage. And as noted, bias ply tires have stiffer sidewalls, so the recommended pressure will be different for radials. The same caution applies to engine tune up settings, which were developed for nearly new, totally stock engines running the gasoline available when the cars were built. Tire pressure and tune up specs today are more of a trial and error process.
I have a '67 chassis service manual, and here's what it has in the Toronado section on tires.
Thanks Joe, great info. Just curious, in your experience, would you say that when it comes to tune-ups using modern fuels do you tend to need more ignition advance or less.......or is it just a crapshoot and you have to fiddle around to figure out what the engine needs?
cfair
Wheels and Tires
June 19th, 2023 02:19 PM
