SSII Center Cap Bolts
Sorry if this is a re-post, but I searched and searched...
What is the correct hardware for bolting the center caps to the wheel on the SSII? I bought a set of SSII, with only 2 center caps and no hardware. I have now bought a set of new caps, but doesn't look like hardware is supplied. I'd like to hit up the hardware store on my commute tomorrow.
I found an image on the web, but it could not find the article it was posted?? Here is what I found, and I can probably match it up with a center cap and this image at the store (if it is correct).
http://i38.tinypic.com/de0h9w.jpg
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Oh fun... Is there a specification to that bolt size? Thread per inch? Nominal diameter?
From the image, I am judging it is 1/4" with 7tpi... I found this:
http://www.fastenal.com/web/products...Id=&rfqLineId=
Their image doesn't match the description, and info does not give a TPI count...
EDIT - 14tpi, not 7!
Here you go. 18.00 for all 20
SSII Center Cap bolts
I got my bolts at home-creepo - a couple bucks for 50 of them.
They fit fine and looked just like my originals, except for the addition of a slot in the hex head, which of course cannot be seen...
![](/forums/attachments/wheels-tires/65877d1365128477-ssii-center-cap-bolts-img_5004.jpg)
