Click Here
New rims
Old Jun 10, 2016 | 11:38 AM
johncj5's Avatar
New rims
I just got new 15" SS1 rims and mounted 255-60 15s on them... they are going to rub like hell if I try driving it with them on the front.
So I got 245-60 15s for the front. I forgot to take a pic with the smaller front tires.
Old Jun 10, 2016 | 12:12 PM
svnt442's Avatar
I had 255/60/15's all the way around on a 1970 Cutlass with no rubbing issues. What are they hitting on?
Old Jun 10, 2016 | 12:16 PM
I've got 255/60-15s on the factory wheels at all four corners of my 69 H/O, with only minor rubbing if you hit a bump with the wheels turned all the way. What's the offset on your SSIs?
Old Jun 10, 2016 | 04:14 PM
tru-blue 442's Avatar
Old School Olds
Maybe try new shocks and springs for a big block for the 69.
Old Jun 10, 2016 | 08:38 PM
johncj5's Avatar
They have a 4.5" offset, there was only 1/2" between the tire and fender/wheel well.
I want to put heavier springs in it anyway to keep the headers from hitting on good bumps.
Old Jun 11, 2016 | 06:25 AM
Offset is the dimension that the wheel mounting surface is offset from the centerline of the wheel. Typically it is zero for RWD GM cars. I suspect you mean 4.5" of BACKSPACING. Unfortunately, without knowing the width of the wheel, backspacing alone doesn't provide enough info.
Old Jun 11, 2016 | 10:36 AM
johncj5's Avatar
Yea, backspace... 4.5" on an 8" rim.
Old Jun 11, 2016 | 11:08 AM
Well, that's just about zero offset. Mine were 7" wide. Are you sure the camber is adjusted properly? With those spacers you have, the upper ball joints might be too far outboard, causing clearance issues.
Old Jun 12, 2016 | 08:15 AM
johncj5's Avatar
I'm going to take it for an alignment, it looks like negative camber with the top of the tire tipped in, I think I'm going to get some new springs first.
Old Jun 12, 2016 | 02:49 PM
svnt442's Avatar
The 8" wide wheel is part of the issue. Mine were in stock 7" wide wheels with no rubbing issues.
LJA72
Jan 31, 2014 08:02 PM
grindlecrew
Mar 2, 2013 04:19 PM
CutlassLegend
Care and Appearance
Aug 6, 2011 11:08 PM
