Click Here
New 18" wheels
Old Dec 22, 2012 | 01:23 PM
Mr Nick's Avatar
New 18" wheels
BG Rod Works by Voss Wheels
Gasser Wheel, 18x9 with 13 offset
255/45/18 front
285/40/18 rear
Goodyear Eagle Supercar
Clear my C5/C6 brakes with no spacers. Plenty of room in the rear, quarter panels have the lip rolled slightly from my previous combo. But I think they would be fine without the lip rolled. Car is not currently running, so I have not had time to put the front suspension through full travel at full steering lock. However, my previous combo was 255/45/17 up front with plenty of room. I'm confident that the extra 0.5" of tire won't be an issue. Front end should come down a hair more once I put the hood back on.
Only full shot:
I was slightly concerned how I'd like the 285 rears on a 9" wheel, but they look great! A slight sidewall bulge to them, but nothing unsafe. I think they help give the rear a 'meatier' look.
Two pics of the rear:
These will be posted for sale:
Old Dec 22, 2012 | 01:33 PM
LI Olds's Avatar
those 18"s look great, almost Hurst like..
Old Dec 23, 2012 | 05:51 PM
gearheads78's Avatar
car guy
Looks great Nick!
Old Feb 7, 2013 | 06:34 PM
real57vetteguy's Avatar
That wheel looks like it was made for your car, Good selection!
Old Feb 7, 2013 | 06:43 PM
OLD SKL 69's Avatar
GM Enthusiast
I like em. Good choice.
Old Feb 7, 2013 | 09:07 PM
Mr Nick's Avatar
Thanks guys! Just dropped it off at the shop for more transmission work, hope it goes smoother at this place than the previous shop.
Old Feb 23, 2013 | 02:31 PM
deejai35's Avatar
Nice clean look. Just the right size.
Old Feb 26, 2013 | 10:25 PM
Butkusfan's Avatar
Larger than I normally like but WHOA! Those look nice!
Good call!
Old Feb 27, 2013 | 03:33 AM
Aceshigh's Avatar
Looks good.
Chevy put that style rim on the new ZL1 Camaro last few years
The classic rims are more centered with a small offset VS modern rims, but they're nearly identical.
Old Feb 27, 2013 | 11:23 AM
Joffroi's Avatar
Runner
I agree with the others postings.... those wheels look sharp! Looking at your signature pic, your previous rims are the same on my car now.
Old Feb 27, 2013 | 02:56 PM
Mr Nick's Avatar
I'm blushing with all these compliments!
Old Mar 3, 2013 | 07:54 AM
Chris J's Avatar
The 18s look great. I want to put 17s on my 68 you said you had 255/45/17 up front how wide were they and what was the off set? and what were the specs for the back?
Thanks for the help your car looks great
Old Mar 3, 2013 | 08:54 AM
Mr Nick's Avatar
Chris - here are the wheels I had on there previously. I think all the specs are in there, but if you have any specific questions just let me know!
Nick
https://classicoldsmobile.com/forums...els-tires.html
Old Mar 8, 2013 | 05:20 PM
Chris J's Avatar
Thanks for the info it will help alot. Is your car lowered?
Old Mar 8, 2013 | 06:35 PM
Mr Nick's Avatar
Yes, it's lowered about 2" up front and I'd say 1.5 - 2" in the rear. I also have a handful of suspension upgrades as well, but I don't think that would affect fitment.
Old Mar 14, 2013 | 01:53 PM
Chris J's Avatar
Nick sorry to keep bugging you with questions but I am having a hard time findind a -6 offset for the rear, the wheels I would like to use are 17/9 have and are +6 offset do you know if they would have clearance problems.
Old Mar 14, 2013 | 01:58 PM
Redog's Avatar
Nice! I like them.
Where the C5/C6 brakes a direct swap, or did you have to mod anything?
Old Mar 17, 2013 | 07:49 AM
Mr Nick's Avatar
It was a kit from KORE3, everything you need is included. Tobin is a GREAT guy to work with, and he'll change the package to suit your needs. Example: I got the pads and calipers from him, but supplied my own rotors. Only read "mod" was matching the master cylinder to the rest of the combination.
http://www.kore3.com/
Old Mar 17, 2013 | 08:00 AM
Mr Nick's Avatar
Chris - if you compare the 17x9 +6 offset wheels you're looking at, to the 18x9 +13 offset wheels I have, your wheels would be moved out 7mm more. If you don't go too wide with the tires, you should be fine. With the fat 285/40/18 I have in the back, if mine stuck out 7mm more, it may hit the quarter panel on bumps, but I'm lowered a decent amount.
What is the exact wheel you're looking at? What size tires are you thinking about using?
I used this website for their calculators all the time: http://www.1010tires.com/Tools/Wheel-Offset-Calculator
http://www.1010tires.com/Tools/Tire-Size-Calculator
Old Mar 17, 2013 | 07:38 PM
Chris J's Avatar
I am looking at FOOSE Legend 17X8 front +1mm offset 4.5 backspace and 17X9 rear +7mm offset and 5.25 backspace. I havent decided on the tires, I just want a good ride. I would like to get as wide as I can with out a lot of side bulge.
Old Sep 29, 2013 | 12:37 PM
ctosiflying's Avatar
Hey Mr. Nick, You just solved my wheel dilemma! :-) I have the perfect project for those wheels. Can you take a full side view and post it? And by reading your post you stated a +13 offset on all four wheels? Correct? I am also going the Kore 3 route. Did you hook up the e-brake? Please let me know. I like your set up! looks awesome.
Old Sep 30, 2013 | 08:54 AM
Mr Nick's Avatar
Chris - didn't see you replied again to this, sorry. Did you end up getting wheels and tires? If so, what combo?
Old Sep 30, 2013 | 08:57 AM
Mr Nick's Avatar
Yep 13 offset front and rear. Currently working on the car, so it's still in the garage. I can take a slightly wider angle shot for you.
I got the Kore3 kit with the parking brake brackets, but didn't buy all the hardware yet. The car had an automatic when I did the brake upgrade, so I didn't care about a parking brake. Now that I swapped to a stick, I don't like leaving it in gear so I'll have to add the parking brake soon. That's why I got the parking brake brackets, I knew I'd add it later.
Old Sep 30, 2013 | 04:03 PM
Nick, I'll take the wide shot thanks.
Old Oct 10, 2013 | 06:16 PM
Offset
Hey Nick, Do you think that a zero offset wheel in the rear would work with a 265 tire with your setup? I'm looking at a deeper lip in the rear.
Old Oct 10, 2013 | 06:38 PM
starfire's Avatar
Didn't think I'd like them from the title, but those look nice. I would like to see a shot from farther away.
Old Oct 11, 2013 | 09:13 AM
Mr Nick's Avatar
Back in the garage today, I'll get a farther shot and post it.
Zero offset in the rear would put them about about 1/2 farther out. I'd say you'll be fine with a 265 tire. Zero offset with my 285's would be very tight on the 1/4 panel lip. If you're running drum brakes in the back, you'll be even safer.
That being said... different offset wheels doesn't always mean different lip size. They may get the different offsets by changing the height of the mounting pad area.
Old Oct 11, 2013 | 03:58 PM
Mr Nick's Avatar
Pardon the low quality shots, best I could do at the moment.
Old Oct 11, 2013 | 05:13 PM
starfire's Avatar
Try shooting it with the sun behind you.
Old Oct 12, 2013 | 06:55 PM
Tell me what you guys think. Hurst resto mod project
Old Oct 12, 2013 | 06:56 PM
  #31
Just some photo
shop magic.
Old Oct 12, 2013 | 09:44 PM
  #32
Mr Nick's Avatar
HA! The angle of that shot is pretty close to my original picture, nice work! I like the 554 engine logo...
I like it, but not sure the gray on the wheels goes with the gold stripes on the H/O.
Maybe something like these on the Hurst Challenger?
Old Oct 13, 2013 | 05:35 AM
  #33
554? I never claimed that I was a good magician. LOL
Old Oct 19, 2014 | 09:28 PM
  #34
442Classic's Avatar
I was just shopping this wheel and was wondering who you ordered them from?
I saw a picture of your car on 4 Wheel Online while checking their page out.
I need about 5" to tuck the wheel up and in on the 87 Buick Turbo T after adding LS1 brakes.
The new wheels really compliment your car too.
Old Oct 20, 2014 | 07:56 PM
  #35
Mr Nick's Avatar
I ordered mine through a local Discount Tire retail store, same price as online and I was able to deal with an actual person and not a computer screen.
That picture of my car has been used on a different site as well, along with fake product reviews. They took posts from me other others (on the pro-touring site) and cut/paste to make fake product reviews... ***** CARiD
Old Oct 20, 2014 | 08:02 PM
  #36
442Classic's Avatar
I understand, I was considering Discount Tire also. I have Rev100 on the T now.
Old Oct 21, 2014 | 06:12 PM
  #37
jpc647's Avatar
I like those a lot. Those are on a late model challenger?
My442
Dec 26, 2017 05:08 PM
jim larson
Apr 1, 2016 02:13 PM
66luvr
Aug 7, 2013 08:11 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
