Click Here
Max tire width for stock '68 442
Old Mar 20, 2019 | 03:24 PM
Bud55's Avatar
Can anyone confirm what the max tire/wheel combo is for the subject car. I want to run 15x8's in the rear and 15x7s in the front unless it's cool to run the 15x8s in the from. Tires will be probably 60/235s in the rear and 215s or 225s in the front. Any help from people that know from experience is greatly appreciated
Old Mar 20, 2019 | 07:30 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I did the 14" to 15" upgrade 2.5 years ago. Here are shots of P235/60R15s (98S RWL), and P255/60R15s (102S RWL). I believe max width for a 15" wheel is 8". I think both of these are 8"
But that 8" max depends on the tire and rim type and the installer. Check these specs: Scroll all the way down to the specs. It gives you all the info.
https://www.bfgoodrichtires.com/tire...l#prod_onglets
Old Mar 21, 2019 | 09:41 PM
SWinner's Avatar
I have Wheel Vintiques on my 68 CS. They are Olds SS1 reproduction wheels, 15X10 with 5 inch back spacing. Tires are BFG Radial TA's 295/50 R15. Nice and fat but maintains 26.6 inch height.
They look and drive great. 15X8 and 235/60 R15 in the front.
These wheels look like the original Olds SS1's. You have to look closely to determine that they are not the original 14 inch. Your original center caps will fit.
I have no issues with rubbing unless I have 2 back seat passengers and only during a dip or corner.
Open the album on my user account for pictures.
https://www.wheelvintiques.com/wheel...obile-ssi.html
Old Mar 22, 2019 | 07:38 AM
Read through here, with the right backspacing you can run all the way to a 295-R50-15 in the rear.
https://classicoldsmobile.com/forums...ost-yours.html
Old Mar 22, 2019 | 07:49 AM
droptopron's Avatar
delete
With the right back apcing you can put a very big tire out back, like others have said, a 285/50.
JMO but a 235/60-15 is a very small tire for these cars in the back, A 255/60 on a 15x8 is no problem.
Old Mar 23, 2019 | 04:21 AM
rob1960's Avatar
I'm running 15x7 with 235/60s in the front & 15x8 with 275/60s in back. The fronts rub the sway bar a little but I'm using a 1 1/4" sway bar. Lots of room out back!
Old Mar 23, 2019 | 12:14 PM
Cool color Rob. Is that 68 K code?
Old Mar 24, 2019 | 04:45 AM
rob1960's Avatar
Yes it's code K ocean turquoise.
Old Mar 25, 2019 | 10:35 AM
hawkk442's Avatar
very sharp ride.
Old Mar 27, 2019 | 06:29 AM
68f8t5's Avatar
Max Tire Size
If you are not looking at keeping the stock look, a 15"X10" with 5.5" backspace and a 295/55/15 fits perfect.
Darkalley
Wheels and Tires
Jul 25, 2019 02:55 AM
w-30dreamin
Wheels and Tires
Mar 8, 2017 10:49 AM
MudEye
Apr 12, 2013 07:06 AM
rocketscientist
Aug 7, 2011 01:52 PM
ttg
Sep 14, 2008 03:15 PM
