Click Here
I need help with new tires
Old Jan 7, 2017 | 02:02 PM
1969CutlassSBlue's Avatar
I want to put this stance on my car, what tires do I need to get, I want redlines, I will post the link to them after the pic of my car. Please any info would help, thank you.
https://www.cokertire.com/catalogsea...85&q=205-75R14
Old Jan 7, 2017 | 02:04 PM
Olds442redberet's Avatar
Definitely an "Old School" look.
Old Jan 7, 2017 | 02:57 PM
The car in the top picture has either air shocks or station wagon springs installed in the rear. The front looks to be at stock height. The tire size in the rear is either 295-50-15 or the no longer available 305-50-15 on 15x10 Cragar SS wheels. The fronts I have no clue, they could be either 60 or 70 series tires.
Old Jan 7, 2017 | 06:47 PM
76olds's Avatar
Hookers under Hood
I agree with Oldcutlass, I think Eric nailed it with air shocks and/or wagon coils, 15x10 50's on the rear and 15x7 or 8's with 60 or 70's series tires up front.
Old school look for sure, handling would be treacherous on tight bends and corners at certain speeds.
Bumpy ride for anyone in the back seat with it sitting up high.
I like the look myself.
Eric
Old Jan 7, 2017 | 07:20 PM
Gary M's Avatar
Gotta ask
is it the wide tire you like or the jacked up rear end. A lot of tire should fit in the rear wells and make a big difference to the look but if you want the jacked up look, shackles and or air shocks will do that. As mentioned and from my experience up in the rear means bad handling, more stress on the front suspension. When I wanted that though I did not care about the down side and enjoyed the look.
Old Jan 7, 2017 | 07:28 PM
How do you put shackles on coil springs?
Old Jan 7, 2017 | 07:31 PM
Fred Kiehl's Avatar
Those rims on the back look bigger than 15 inch.
Old Jan 7, 2017 | 07:33 PM
Gary M's Avatar
Very carefully
reliving my youth. Shackles obviously won't work. Thanks for bringing me back
Old Jan 8, 2017 | 08:07 AM
Mr Nick's Avatar
Those rear wheels in the first pic may even be low-offset 15x8, judging by the amount of sidewall bulge on the tires. I do agree those rear tires are probably 295/50/15. I believe you can get that size in BFG and Cooper.
If you plan on using the stock wheels you have posted in your 2nd pic, DO NOT mount a 295/50/15 tire on them.
Old Jan 8, 2017 | 02:09 PM
The jacked-up, tires-sticking-out-of-the-fenders look came and went with the mullet. I wouldn't go there.
Old Jan 9, 2017 | 07:02 PM
Smallhurst's Avatar
You are wrong with this statement!! The Day 2 thing is picking up strong.
If you have 15" rims, I can set you up with L60-15 Polyglas RWL in back (equal to 275/60/15) with F60-15 (equal to a 235/60/15) up front. This gives you about a 2 " rake and give you the stance shown in the top picture.
As for help with the rear, stay away from air shocks and go with spring spacers. If the wheels are proper backspacing, that wheel/ tire package won't hang out too far, but you want to do your measurements.
As for redstripe, you are going to be limited on going with wider tires, but if you go to Diamondback, they can custom make redstripe radials in the sizes you want.
Old Jan 9, 2017 | 08:59 PM
ah64pilot's Avatar
Nick is right, those are definitely 295/50's on an 8" wheel. Same combo I had on my car before the new wheels. 8" was the minimum width for that tire.
Agree that the look is dated.
Old Jan 10, 2017 | 07:36 AM
The "Day 2" thing is another BS term made up by the high dollar auction houses to justify an excessive price for a car that isn't correct. You can build a car any way you want. The jacked up look with tires sticking way out from the fenders died for a reason. It looks like Joe Dirt and screws up handling. We all did crap like this when we were young and stupid. Some of us wised up.
Old Jan 10, 2017 | 08:12 AM
Rocketguy's Avatar
LOL
Very well stated Joe. I did it too in the 70s.
Old Jan 10, 2017 | 08:24 AM
While my tires don't stick way out of the wheel wells, I like the lifted look. Although mine is lifted front and back.
Old Jan 10, 2017 | 01:53 PM
midrange's Avatar
Shaking out the cobwebs..
I like the raked 15x10 wheel with 295/50 tire look.
No.... I LOVE that look.
I know it's the worse thing for handling, but I'm not out for anything other than Friday/Saturday cruise nights and car shows anyways.
I'm going to do the same to mine, I just don't know if I want to custom order a 5" backspace on the wheels.
When I can get the car out of it's winter slumber, I'll be able to get to work on figuring the wheel dimensions and how to best achieve the lifted rear.
It definitely won't be air shocks. LOL
Old Jan 10, 2017 | 02:33 PM
Pfiffle's Avatar
I love that look. A chopper Harley with Apehangers suck to ride, but looks cool. Same thing.
Tom
Old Jan 10, 2017 | 03:04 PM
71cutlass350's Avatar
Im doing the same look with my 71, I love the raked look. I have all the parts numbers for the shocks and rear springs I used also. Just went through Moogs site and found a spring that matched my specs and my desired height.
Old Jan 10, 2017 | 07:23 PM
76olds's Avatar
Hookers under Hood
I like the look as well, looks to be sitting up nice. I put vista wagon coils in the rear of my 76. Pushed it up a good 4". You car is going to look great after paint. Like the rims and Goodyears. How new are your Goodyear tires, I couldn't find RWL when I looked at Goodyear tires 2 years ago. I just went with the reliable BFG's.
I'm getting tired of the BFG'S time for a new tire look on my 76.
Eric
Old Jan 10, 2017 | 07:41 PM
The rims and tires are atleast 10 years old and quite dry and cracked now so after the restoration I'll definitely be going with new tires and probably rims. Might look at going to 17 inch rims just for more variety in tire options.
Old Jan 11, 2017 | 06:44 AM
ah64pilot's Avatar
You might look at 18" wheels for even more tire options. I always felt the 17" rims were still a little "off" on our cars. 18"s seem to fill the wheel well better while giving you a great fitting tire too. If your budget allows, a nice set of 18's with the right tire will completely change the look of your car.
Old Jan 11, 2017 | 06:52 AM
Wheel diameter is irrelevant. Start by looking at lists of available TIRE sizes and diameters. Pick the TIRE you want, THEN pick the wheel size. Most 17" tires on the market are very low profile and too small for an A-body (or, they are truck tires).
Old Jan 11, 2017 | 05:08 PM
Good point about picking tires first. Still not sure how 17s or 18s would look versus 15s since I'm going for the 80s hot rod look. Some classic style 15s might be the best fitting for the look.
Old Jan 11, 2017 | 06:52 PM
If your going for the 80's look, I'd stick with 15's.
jnaarnold
Sep 12, 2017 08:09 PM
navvet
Feb 3, 2014 02:44 PM
oldsguybry
Wheels and Tires
19
Feb 16, 2013 09:14 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
morrowjm
Oct 13, 2010 11:17 AM
