G body rally wheels on A body
Will 80s g body rally wheels fit A body cars? I have a cutlass and I'm getting different information some say yes some say no. It's the same bolt pattern not sure on the hub size. So will they fit?
Thanks I read so much people tell me that it's lug centric , hub centric and some said it was hitting the calipers so much information got me confused. Some said center bolt caps don't fit so I wasn't sure. There the stock rally wheels from g bodys
As far as I know all Oldsmobile SSII/SSIII wheels are lug centric. You just have to use the correct lug nuts. I think the only issue would be if you tried to use older wheels with less offset on newer cars. I have 15 x 7 snap on cap SSIII wheels on my 1970 Cutlass with no issues.
Sometimes, but in this case no. The G-body cars use metric wheel studs, the A-body cars use 7/16-20 wheel studs. The nuts need to match the studs. They are just normal taper seat lug nuts, nothing esoteric.
