Click Here
Cleaning RWL tires
Old Sep 18, 2016 | 08:12 PM
Ryan McManus's Avatar
Cleaning RWL tires
What's everybody's technique on cleaning and getting letters bright white on rwl tires
Old Sep 18, 2016 | 08:29 PM
steverw's Avatar
This question has come up alot, my answer is always Comet or Ajax cleanser and a good stiff brush. Use it on the black walls too, it works great and will make the letters bright. Its what i have been using for 40 somethin years. Just try it, its cheap to try. Go to the Dollar store, cleanser and a brush for a couple of bucks.
Old Sep 18, 2016 | 08:50 PM
I get whatever "bleach white" spray is on sale at the auto parts store, and use a grill brush. Use a regular scrub brush on the whole tire, looks so good I don't need Armor All.
Old Sep 18, 2016 | 08:59 PM
I use Westley's Beache White, and a stiff nylon brush, or 409/Fantastic kitchen cleaner.
Old Sep 18, 2016 | 09:37 PM
anthonyP's Avatar
Good suggestions. If RWL or sidewall has tough stains, I've used steel wool, but very lightly. Personally dislike the shiny Armor All look on tire sidewalls.
Old Sep 19, 2016 | 08:44 AM
X2! (though the "spray on, wipe off" is somewhat optimistic...)
Old Sep 19, 2016 | 08:52 AM
oldsmobiledave's Avatar
Fyi
Mr Clean Magic Eraser
Old Sep 19, 2016 | 09:02 AM
texxas's Avatar
I use Westley's Beache White, and a stiff nylon brush.
If only you could still buy Westley's... Don't waste your money, It's now called Black Magic Bleche Wite, it takes twice as much to clean half as well as the old stuff. It smells different and just doesn't work like it used to. I'm back to the old Ajax and a scrub brush. I see so many classics with dingy white letters. I watched a Mecum auction awhile back and 5 or 6 cars in a row had dingy brown tinged lettered BFG tires. If you didn't know better you'd think that's what color they come when new.
Old Sep 19, 2016 | 09:20 AM
Local Hero's Avatar
Turn the tires around and put the letters inside.
Personally, I'm not a fan of RWL tires. Why would you give the tire company free advertising after having spent a small fortune for the tires already?
Old Sep 19, 2016 | 09:49 AM
Just a note, Westleys Bleach white and other caustic cleaners do not get along with polished aluminum wheels. Be prepared to polish them if they are not coated directly after use.
Old Sep 19, 2016 | 11:59 AM
61Bat's Avatar
I use white shoe polish with the foam applicator to get them bright white....but I've got redlines now lol.
Old Sep 19, 2016 | 01:00 PM
droptopron's Avatar
delete
Also note, the white these days just isn't as bright as it used to be. I had Radial TA's when I had my Trans Am & they never looked as crisp as they did back in the day. However, my current Firestone Wide Ovals come up pretty freaking white.
Old Sep 20, 2016 | 09:08 AM
Don R.'s Avatar
I like good old fashioned SOS pads.
Old Sep 20, 2016 | 06:03 PM
76olds's Avatar
Hookers under Hood
I use spray nine but SOS pads and comet sound good as well.
Old Oct 1, 2016 | 04:25 PM
Smallhurst's Avatar
Wesleys, SOS, and elbow grease.
If you have really bad stains on the white letters, you can sparingly use lacquer thinner. Get it on and get it off!!!
Best thing to use on tires, is nothing at all. If you want your tires to last an not turn to brick!!! Scrub them with bleach white and a stiff brush and they are good to go.
Old Oct 2, 2016 | 04:28 PM
ignachuck's Avatar
Frank Ignachuck
X2 on SOS pads
Old Oct 3, 2016 | 04:35 AM
jpc647's Avatar
^This. Works Well, but you gotta keep up on it. Do it a couple times a year.
Old Oct 3, 2016 | 10:27 AM
marcar1993's Avatar
Sos pads here too, white letter or white walls/stripes. Nothing cleans like these. Sometimes I'll use bleach white with the Sos pad.
Trick: If you use any tire shine, make sure too use a clean paper towel to remove it from the white, it attracts dirt and the carbon from the black tire will sometimes run onto the white.
Ctls442
Oct 30, 2017 10:21 PM
DownBoy
Oct 4, 2016 11:34 AM
nelsontj
Jul 24, 2014 05:49 AM
dcurtis61
Apr 10, 2013 09:01 AM
joades
Aug 30, 2009 01:53 PM
